My Ferguson Continental 135 engine cant find where to hook up the oil gauge line
   / My Ferguson Continental 135 engine cant find where to hook up the oil gauge line #1
Knifer
Bronze Member
Winter Haven
Massey,JD 2010, International W6. '42 case
any Ideas where the oil port is?
   / My Ferguson Continental 135 engine cant find where to hook up the oil gauge line #2
I happen to have a picture I took while working on mine.
The oil gauge line connection point is located just to the right of your battery negative post connection point to the frame on the right side of the tractor. Just to the left of the oil filter.
You should use a line wrench when loosening or tightening it. I would put a bit of teflon tape on it upon final assembly. When you hookup to the gauge you will need to bleed the line at the gauge while engine is running till you see oil comming from the line then tighten securely. If you don't. Your gauge will either not work right or be inaccurate. -robert
thaanks
John Deere 772-A Grader (A52384)
John Deere 772-A...
2015 PCI MFG. SOLUTIONS 130 BBL STEEL VACUUM TRAILER (A53843)
2015 PCI MFG...
CABINET OF HOSE ENDS (A53843)
CABINET OF HOSE...
2014 TROXELL 130 BBL VACUUM TANK (A53843)
2014 TROXELL 130...
2018 Mercury Verado 250HP Outboard Boat Motor (A51694)
2018 Mercury...
