My dream tractor: is there such a thing?
   / My dream tractor: is there such a thing? #21
I think these machines are pretty neat.
Aebi TT206 (Terratrac) | ASH Aebi Schmidt Holding AG
   / My dream tractor: is there such a thing? #22
The problem is keeping PTO power transfer and equipment aligned when pushing. Only modest mechanical power transfers are possible pushing, then hydraulic power transfer is required.
When pulling everything self-aligns.
I can see several workable solutions to that problem. Ever watch a haybine or wheat combine at work?
   / My dream tractor: is there such a thing? #23
1) Not exactly a tractor really, but basically an articulated loader, for tight quarters maneuvering without tearing up the ground.
2) SSQA loader to accept my existing attachments
3) front hydraulics with enough flow to run a 5 ft., front mounted bush hog
4) 4WD with big tires all around
5) 40 to 50ish HP
6) maybe a heated cab but low profile for mowing around trees. (Or easily removeable in nice weather.)
Is there such a thing?
Here is my dream machine, cab with heat and air, SSQA, 6' wide, 6.5' high and 13' long. Tire size is 14x17.5. Top speed is 15.5 mph, drawbar pull is 7,000 pounds, boom breakout force is 6700 lbf, bucket breakout force is 4700 lbf and it will lift over 5,000 pounds, 17 feet high.
7' front mounted brush hog.
40' oak tree and a 5x6 round bale.
6' wide, one cubic yard bucket.
And it is unstuckable! :thumbsup: http://www.tractorbynet.com/forums/...t/160568-compact-telehandler.html#post3526054
   / My dream tractor: is there such a thing? #24
There usually isn't one machine that will do everything. I love my articulated toys but they can be very unstable on slopes and you have to be very quick and clear minded to avoid over turning! Plus, you can get really close to things that you then can't get back away from!
The tractive effect is just awsome, with four equal sized wheels running in the same track! But the absolute best thing about (most) wheel loaders is the visability to the tool, unmatched only by a skid steer, but the operators view and comfort are just that much better.
   / My dream tractor: is there such a thing? #25
Power Trac has a 45 degree slope mower. My PT425 is highly stable on side slopes, too.
   / My dream tractor: is there such a thing? #26
View attachment 414642 View attachment 414643
View attachment 414644 View attachment 414645
View attachment 414646 View attachment 414647
View attachment 414652 View attachment 414653
Yeah, a V417 is exactly what comes to mind when I think of an articulated loader for tight quarters maneuvering around trees with no cab.
OP here.
You guys either own, or have dredged up, some interesting tractors for me to check out. Ferrari seems to be a collection of some European possibillities but their web site just shows a superficial overview. And I like Ferrari99's recommendation- It looks like a hybrid-tractor/dune buggy.
Still, in Indiana, well away from the vineyards, buying one of these exotics, well away from dealer support, and reselling it when the time comes, might be hard to justify.
Thanks, All.
   / My dream tractor: is there such a thing? #28
Would this work for your mowing? :D
I think it has a little more hp than you requested and it might not be very gentle on the turf with the bear paw ring chains!
   / My dream tractor: is there such a thing? #29
I used to have this Dynalift. Got it stuck once in the wetlands and yes, with some work, it extricated itself. I kind of miss the old girl, especially if I need to tweek something on the underside of my Ride! Scary as heck when twelve tons starts sliding on ICE!
   / My dream tractor: is there such a thing? #30
I was just showing a better machine than an articulated loader, "for tight quarters maneuvering without tearing up the ground". The OP wanted a cab.
I use the V417 in the woods a lot, with 4 wheel steering and 6.5' cab height, it will go where tractors and loaders can't.
Cub Cadet Kohler mower 7000 series (A50324)
Cub Cadet Kohler...
2000 Mercedes-Benz S-Class Sedan (A53424)
2000 Mercedes-Benz...
2018 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A56129)
2018 FREIGHTLINER...
CFG MH12RX Mini Excavator (A49461)
CFG MH12RX Mini...
2008 Chevrolet C7500 Truck, VIN # 1GBM7C1G78F413329 (A54865)
2008 Chevrolet...
2014 VOLVO A25G ARTICULATED DUMP TRUCK (A51406)
2014 VOLVO A25G...
