TripleR
Super Star Member
- Joined
- Mar 5, 2009
- Messages
- 18,538
- Location
- Missouri
- Tractor
- Kubota M8540HDC, L5740HSTC, BX2200, BX2660, John Deere 425&1025R, Case, Massey Ferguson, Ford
Gradually defining where you want the water to flow towards the pond with a box blade (and quickly re-seeding to prevent erosion) sounds like a good plan.
Can not tell by the picture, but where does the pond water overflow to when the pond becomes full? It sorta looks like the far side of the pond (opposite your property's drain flow swail) is the overflow for the pond for when it becomes full. Regardless, I would want to know where the pond overflow is and where the excess pond water has to go before I altered things.
Also, I have had good luck using a cheapy 3-pt subsoiler attachment to break up subsoil clay to get the water to simply soak into the ground quicker in those areas where it is not feasable to divert water away. Be mindful of existing drainage tiles, sewer lines, fiber optic lines, power lines etc. before attempting to subsoil anywhere. The subsoilers are great in that minimal damage is done to the existing turf - simply looks like a big knife slit in the ground, but they drastically help the water soak into the ground. Subsoiling can last in an area for multiple years too. It has been several years since I last subsoiled some of my problem areas, but I do plan to do hit them again this year though.
Very good idea for many applications.
How to use a subsoiler
