KevT
- Joined
- Apr 1, 2015
- Messages
- 491
- Tractor
- Kubota L3901 HST w/ FEL, ST2046
Hahaha, Hey Brandi, Would you believe I actually went to a "Tapcon" school to learn about them. The biggest problem you will have is that they will corrode and rust and be useless in 3-8 years. The copper sulfate in the pt lumber will eat the finish then the screw, rain and moisture will attack what is exposed because the nut driver rubbed the paint off. Now let us think about this tapcons are about 40 cents each (in bulk from warehouse store not home depots 25 ct box) sleeve anchors are about 1.75 each. It is much easier and cheaper to just replace the tapcons when you need to. You are not using them as a structural placement. If it were me there would be no question, tapcons are the next best thing since Velcro!!!
Now make sure your concrete is cured (hard) because they will strip in mason block and green concrete
Hope that helps,
Kev
Hope that helps,
Kev
