My 50 hour service
/ My 50 hour service #1
Matt_W
20 mile West of Pittsburgh
B7610
Well I did my own 50 hour service on Monday on my B7610 and it was not too bad! I bought a 5 gallon oil catch basin previously and could catch all 3 streams of hyd oil at once! I bought a 26mm socket for the hyd strainer and had a 14 mm/17mm for the engine oil/hyd drain plugs. When I asked the dealer about doing it they basically said yes well take your money. If you ever changed oil on a car then can't see why you could not do the tractor. /forums/images/graemlins/smile.gif
/ My 50 hour service #2
I'm 43 hours away from doing that myself. What are you planning on doing with the old fluids? Did you mix them all together? Can you recycle them mixed together?
Thanks.
I am taking all my hyd oil to the auto parts store where they will test then dispose of. I will keep the engine oil to use for lubricating my log splitter. I will ask them if it is OK to mix them and let you know.
/ My 50 hour service #5
As for your waste oil, My state, Texas has a law that if you sell oil , then you must allow customers to dump oil in collection container at no charge. Is a good law.
/ My 50 hour service #6
</font><font color="blue" class="small">( As for your waste oil, my state, Texas has a law that if you sell oil , then you must allow customers to dump oil in collection container at no charge. Is a good law. )</font>
In Wisconsin, we have hazardous waste sites that have to take residential toxic waste for free (not asbestos of course). That is what i do with all my waste oils and fluids.
Bob
I finally made the time to get rid of that waste oil and you hear. Tanks full!!!!
I did ask about mixing hydro and motor oil and they said that as long as it pass's the mandatory test then no problem.
/ My 50 hour service #8
What do they test it for?
Ruebella, smallpox, learning disabilties.
Y'know if it's a test for the abilty to serve as a politician
I don't think they would have many failures.
/ My 50 hour service #9
I did the 50 hour service on my L4400 last weekend. All-in-all not too bad. Several thoughts:
1) It was expensive. I used Super UDT and the total was nearly $300 for fluids and filters.
2) There is a lot of fluid to deal with, at least in the L4400. The tranny fluid alone is nearly 11 gallons. A 5 gallon bucket will not fit underneath so I had to use a galvanized wash tub and then transfer the old stuff into the empty UDT buckets later. Very messy.
3) Access to the fill holes was difficult. The hydro/tranny fluid goes into a hole over the 3pt hitch. A cross bar with the tool box and rear remotes is very much in the way. I removed it and used a long stem funnel to get access. The narrow caliber of the long funnel made filling a little slow. The engine oil fill hole was a little better.
4) The drain holes for the front axle are in a bad position. They are at the bottom of the bevel gear housing on either side. They are easy to get to but almost impossible to get a catch basin under them. I lifted the front end with the loader and that helped. Probably should have removed the front wheels too. You also have to tilt the axle up and down to get each side empty, meaning that two catch basisns would be best. As it worked out, I did get some fluid on the ground.
The whole deal, including clean up (the hard part), probably took me two hours. I went slow since this is my first tractor. Not bad, but I'm glad its done. And glad it will be a long time before I need to do all of that again.
mumps seem to be making a come back maybe that. /forums/images/graemlins/smile.gif
I am not positive but I think it is a chlorine test?
/ My 50 hour service #11
In the old days, hydraulic fluid contained PCBs. PCBs worked great; they never broke down. Unfortunately, they are also a hazardous material, and as such much $$$ is needed to dispose of it. If any of old PCB-containing oil was mixed into used non-PCB hydraulic fluid, then all the contents of the container become hazardous. PCB stands for Poly-chlorinated Biphenyls. That is why they check for chlorine content.
/ My 50 hour service #12
When I do my servicing on my L5030 and have to add hydraulic fluid I went down to the local hardware store and bought about 18" of 1" clear vinyl hose and stuck it on the end of my funnel to reach the opening for the hyd. fluid. It makes for an easier and less messy fill up.
Kevin
iDrive TDS-2010H...
2000 Malibu (A62613)
John Deere 50 (A60462)
New/Unused CFG Industrial H15R Mini Excavator (A65583)
New/Unused CFG...
Ford F800 (A63689)
Ford F800 (A63689)
2023 Deere 317G (A64119)
2023 Deere 317G...
