MX6 or LX6 for 4320 Tractor
/ MX6 or LX6 for 4320 Tractor #1
peddler
Hey guys. I just recently purchased a new JD 4320 tractor. It's time to purchase a rotary cutter for it and I had almost decided on the MX6, but the the salesmen I spoke to at two different stores seemed to steer me away from it saying it was too much cutter for the tractor. I know on the website it lists the MX6 as a possible attachment. I was just wondering if any of you have this cutter with a tractor of this size and your opinions. Any help or information you have is appreciated. Thanks.
/ MX6 or LX6 for 4320 Tractor #2
I have an old, unknown brand 6' cutter that I use with my 4320. I use it in the pastures. It works fine; although I did manage to slow the tractor down, climbing a 20 degree slope, cutting very thick ryegrass. The saleman at my dealer was eager to sell me either the MX6 or LX6 so I'm thinking that under reasonably average conditions you should have no problem.
I guess I was just a little discouraged after the salesmen both seemed to think the MX was too heavy for the tractor. At least that's the impression I got. I only need the cutter about three or four times a year, but I thought I would just step up to the MX in order to be able to cut thicker brush if I ever need to do so. Your salesman seemed to think the MX would be fine though?
/ MX6 or LX6 for 4320 Tractor #4
Yes, he did. For occasional use though, why spend big bucks for the MX6? My dealer told me $2300 for MX6 and $1500 for LX6. Shortline brands are a lot less.
My dealer was actually selling the MX6 for $1975.00 and the LX6 for $1455.00
I just wanted to have a cutter that would handle almost anything I might ever want to cut, but not unreasonable for my tractor to handle.
/ MX6 or LX6 for 4320 Tractor #6
A 4320 will handle an MX6 just fine. Power is not an issue. If you don't have a loader on the front end you will need front weights. These aren't cheap so factor the cost into your decision. Your dealer should be able to advise you on the number of weights required. John Deere publishes this information I think in their sales manual and I would think it is also in the MX6 operator's manual.
/ MX6 or LX6 for 4320 Tractor #7
Peddler,
I am pulling a 6ft rotary cutter with a 4400 that has less than 30hp at the PTO. It usually will cut as fast as I want to travel through the tall stuff. So, that indicates to me that you have more than enough power to pull the MX6. The only issue is the weight of the MX on the back of your machine. The MX appears to be an excellent machine and I wish my tractor would handle one. If I was in your shoes I would buy the MX without hesitation, as long as I could mow without a loader on the front.
/ MX6 or LX6 for 4320 Tractor #8
That price on a MX-6 is very good. You should check the configuration to make sure all the "standard" features are included. I had that happen to me - the price was really good, but if I wanted rear chains - that was extra...
I run a MX6 on my 4720 and it is awesome. Your 4320 should do fine.
D.
/ MX6 or LX6 for 4320 Tractor #9
I ordered an LX knowing full well that I really wanted an MX - but the 4310 isn't rated for it. Well, My dealer said I was stooopid and ordered an MX for me. My 4310 is just on the edge with the MX, but we do fine with it.
A 4320 would be perfect pulling an MX. (maybe the salesman have been burned selling them, because they are so spendy...)
I know there are many happy LX owners. But I rarely advise buying it. The sidewalls are too thin in my estimation. Swing wide once and smack a fence post and they will likely crumple. Taping 5 $100 bills onto one won't make it an MX which also has a far superior gearbox, stump jumper, top, and frame.
I feel that the Deere cutters perform better than most. The cutting chamber is engineered for fast clean cutting. Some brands will have real engineering, but not many to the level of Deere's.
As DDivina points out, the standard features can be deleted by the dealer. So one or both sets of chains might not be in the price. In the LX the slipclutch can also be deleted. Don't assume they do this stuff to be 'crooked' there are several reasons why they can come this way. Price is just to most common.
/ MX6 or LX6 for 4320 Tractor #10
I'm a proponent for buying more than you need - and if the MX6 works for your 4320 (rating), then go for it. I have one for my 4600 and it really rocks!
-Bob
Thanks for the responses guys. After reading your posts this morning, I called my local dealer and had him deliver the MX6. Wow, this is an awesome cutter. I couldn't be happier. All of my concerns were over after a couple swipes through some pretty thick brush. The tractor handles it very well in my opinion. The price did include both front and back chains. ($1975.00 + Tax) Thanks again for your input. I had almost decided to change to the LX after listening to a couple salesmen, but now I'm very glad I stuck with the MX.
/ MX6 or LX6 for 4320 Tractor #12
$1975 is an AWSOME price. You definately did NOT go wrong..!
Congrats!
Now, check out the thread on bushings/sleeves/kits if you have an i-Match! :cool:
-Bob
/ MX6 or LX6 for 4320 Tractor #14
Hmm. :eek:
In the illumination of the great Mike, I am smiling. :)
(but seriously - the MX6 really kicks butt...!)
-Bob
/ MX6 or LX6 for 4320 Tractor #15
Peddler,
Are you able to handle it without the loader on? In any case, that is a great deal on the MX. Congrats and enjoy.
I am able to handle it just fine without the loader. Actually at this point I don't even have front weights either. I do intend on getting some if I don't get the loader sometime soon. It does make the front end light of course, but it handles it surprisingly well.
/ MX6 or LX6 for 4320 Tractor #17
Are your front tires filled? It doesn't take much, and can make a surprising difference. You can get a fill adapter for $6 and use windshield washer fluid. The only problem with front suitcase weights is that they have to come off to use the loader. Of course, a lot of folks like having the loader on when they brush hog. Use it as a feeler to find rocks and a handy place to store them. I can't begin to use my MX without the loader on - the 4310 would just do wheelies, so I can find lotsa excuses to have one... :)
I don't have the front tires filled. Where can I find the fill adapter you are referring to? I'm hoping to get the FEL in a few months or so, but I'm certainly interested in filling the front tires until I decide on purchasing one.
/ MX6 or LX6 for 4320 Tractor #19
Drop by sometime and I will loan you mine!
or:
Tractor Supply, NAPA, try AgriSupply, or Northern. A good feed store.
It screws on the valve stem (core removed) and has a garden hose fitting, plus a air bleed button. You can hook it straight to a garden hose or a little pump. You have to bleed air from time to time.
A buddy of mine breaks the bead and just pours the fluid in.
Try Gempler's:
http://http://www.gemplers.com/a/pages/tliq.asp
/ MX6 or LX6 for 4320 Tractor #20
Cool deal on the mX6. I just put some hours on mine - it sure is a tough mower. I still dent it here and there, but it should last a lifetime. That price is smokin'. Did it come with the clutch also? My dealer is quoting liek $2200 on them here.
D.
2008 Freightliner B2 Bus, VIN # 4UZABRDJ98CZ17952 (A61165)
2008 Freightliner...
2025 12v Fuel Pump (A61568)
2025 12v Fuel Pump...
2014 Chevrolet Cruze Sedan (A61569)
2014 Chevrolet...
2014 JEEP WRANGLER POLAR (A62130)
2014 JEEP WRANGLER...
2019 John Deere R-4038 (A63118)
2019 John Deere...
New/Unused Two Wheeled Electric Bike (A61166)
New/Unused Two...
