MX5800 rotary cutter opinions
   / MX5800 rotary cutter opinions #41
Mr. BDHSFZ6, what articulating flail mower do you own?
It's a Maschio 180SE
The pic shows it on the L6060 but I also use it on the MX5800.
Doesn't cut quite as fast as the Brush Hog, but it does a better job of mulching. It's also much more versatile since it also cuts ditches, banks and vertically along the tree line.
   / MX5800 rotary cutter opinions #42
I had a Woods BB600X. Bought it for small pines and brush. It was overkill and Heavy Duty for what I was doing. It was really too much for my New Holland TC40 but it turned it and worked. Gearbox was rated for 120 HP. See pic below to get an idea of how big and heavy it was. I set a big chainsaw lube container next to it to show how big it was.
View attachment 3492795I eventually sold it amd bought a Woods BB72X. Much better and cuts up to 2 inch. It is medium duty and handles everything I throw at it. Just make sure you are aware how heavy some of these units are and make sure you really need that capability.
They don’t look as heavy as they are when I have looked up the actual weight.
   / MX5800 rotary cutter opinions #43
One other issue to consider is its weight.
My 700 lb Woods 72 in cutter is relatively easy to hook up the the 3 pt hitch. Sometimes I have to manhandle it using a heavy steel rod or a 2 x 4 to assist lining up with hitch pins.
I also have a much heavier 8 ft Bush Hog that weighs about 1700 lbs. It is not so easily maneuvered.
I work alone and at 81 had trouble aligning implements for hitching like the 7ft bush hog and swapping in/out the flail mower. I invested in "Jiffy Hitch" self-centering frames and housings which solved that problem. Not cheap but solid, well made. If interested & you can't find them in a search let me know.
   / MX5800 rotary cutter opinions #44
Long stout pry bar works for me.
APPROX 500 GALLON FUEL TANK (A51248)
APPROX 500 GALLON...
2016 CATERPILLAR 325FL EXCAVATOR (A51246)
2016 CATERPILLAR...
LMC LOT IDENTIFIER 130 (A53084)
LMC LOT IDENTIFIER...
1994 Toyota 6000lbs 2 Stage Forklift (A53472)
1994 Toyota...
2022 John Deere 4066M Heavy Duty MFWD Tractor (A53342)
2022 John Deere...
