MX5400 cab compared to L5460 cab
/ MX5400 cab compared to L5460 cab #21
The front & optional rear cab lights suck. They are just a cheap halogen bulb with moderate light at best. A LED cube or mini-bar will do you a lot better & cost less than the $120 Kubota wants.
All the wiring is already there. You just need to plug in the switch & connect the wires to the lights. Connectors are a bit funky on the lights, so probably easiest to cut them off & put more common ones on.
I went way overkill on mine with new wiring, a new fuse/relay box & 46-52" LED bars. Might just have gone with mini bars on the stock wiring if i had it to do over again. Would take me an hour to install 4 maybe a hair more if I had to pop the roof the find the ends of the wires tucked up under there. https://www.tractorbynet.com/forums/customization/376458-let-there-light-l4060-light.html
New/Unused Pallet of Webbing Slings (A65583)
New/Unused Pallet...
2021 PETERBILT 367 (A65643)
2021 PETERBILT 367...
21ft Gooseneck Hay/Pine Straw Trailer (A65563)
21ft Gooseneck...
2023 New Holland Boomer 45 Tractor (A65579)
2023 New Holland...
2018 PETERBILT 567 (A65643)
2018 PETERBILT 567...
2018 Chevrolet Tahoe SUV (A64557)
2018 Chevrolet...
