MX5200 Treadle Pedal Adjustment
   / MX5200 Treadle Pedal Adjustment #1
AndyMA
Elite Member
Windham County, Conn
Ford 2120 , Kubota MX5200 , Deere X748SE. 1956 Economy Tractor
My treadle pedal and starting interlock have been fine for several years. All of a sudden it won't start unless I position the pedal by hand so the tractor goes slowly in reverse. The pedal also is much harder to move and won' t return to neutral. Does anyone know where the switch is and how I can adjust this? Thanks
   / MX5200 Treadle Pedal Adjustment #2
Bump...
I have a similar "feature" on my MX6000.
I need to slightly touch the reverse side of the peddle for it to start. Lubricating the linkage has no effect.
Any guidance on how to adjust the Hydro peddle start lock-out?
   / MX5200 Treadle Pedal Adjustment #3
   / MX5200 Treadle Pedal Adjustment #4
Bump...
That model is new enough that it should still be under warranty.
2015 JOHN DEERE 310K BACKHOE (A51406)
2015 JOHN DEERE...
2003 Chevrolet 3500 (A50120)
2003 Chevrolet...
2021 Fendt 1050 Vario Tractor (A53342)
2021 Fendt 1050...
Tandem Axle Rear Truck Frame (A51692)
Tandem Axle Rear...
2025 New/Unused Wolverine Pallet Fork Frame with Forks (A51573)
2025 New/Unused...
Case TR270 Compact Track Loader Skid Steer (A51691)
Case TR270 Compact...
