MX5200 Treadle Pedal Adjustment
/ MX5200 Treadle Pedal Adjustment #1
AndyMA
Elite Member
Windham County, Conn
Ford 2120 , Kubota MX5200 , Deere X748SE. 1956 Economy Tractor
My treadle pedal and starting interlock have been fine for several years. All of a sudden it won't start unless I position the pedal by hand so the tractor goes slowly in reverse. The pedal also is much harder to move and won' t return to neutral. Does anyone know where the switch is and how I can adjust this? Thanks
/ MX5200 Treadle Pedal Adjustment #2
Bump...
I have a similar "feature" on my MX6000.
I need to slightly touch the reverse side of the peddle for it to start. Lubricating the linkage has no effect.
Any guidance on how to adjust the Hydro peddle start lock-out?
/ MX5200 Treadle Pedal Adjustment #3
/ MX5200 Treadle Pedal Adjustment #4
Bump...
That model is new enough that it should still be under warranty.
2016 Ford F-150 Pickup Truck, VIN # 1FTEW1EG0GKE69622 (A65563)
2016 Ford F-150...
(INOP) 2013 MACK ELITE LEU633 GARBAGE TRUCK (A64280)
(INOP) 2013 MACK...
2020 Crown Concrete Mixer (A65579)
2020 Crown...
New 5400LB, Rachet Binders and G70 Chains (A62679)
New 5400LB, Rachet...
(2) New 27X8.5-15 turf tires in John Deere 6-lug compact tractor rims, Coal Valley, IL (A65640)
(2) New 27X8.5-15...
2011 BRENNER TANK TRAILER (A65643)
2011 BRENNER TANK...
