MX5100 shredding
   / MX5100 shredding #1
bigbull338
Elite Member
texas
7040 HDC 1153 fel
for those of you wondering if a mx5100 can handle a 3pt 6ft shredder in heavy shredding the answer is yes.i run in low at 1800 to 2000rpms.an the shredder goes through anything i ask it to.you need to run at 2000rpms for heavy stuff an drive slow.
   / MX5100 shredding #2
I sure believe it, I ran a Land Pride RCR2672 on our L5030 through the same stuff as our M8540 with a Woods DS1260 and the MX seems a bit more robust. I ran 2250 I think with the 8540 and about 2600 or so with the 5030.
   / MX5100 shredding
i dont like the blades spinning at 540 because i dont know what i could hitt.but its a great tractor for everything i ask of it.
   / MX5100 shredding #4
I also would think so. I have two smaller Kubotas that'll shred everything the tractor will push over. :D
   / MX5100 shredding #5
I get a better cut and smaller pieces running at PTO speed; often cut saplings, brush etc. and the cut looks cleaner on grasses.
   / MX5100 shredding #6
I use an rcf2772 with mine. I always run at or near pto speed for a better cut and higher ground speed. Usually cut in 5th or 6th gear depending on conditions.
The mx5100 has plenty of power for a bigger cutter but I settled on a stout 6ft model due to cost.
   / MX5100 shredding #7
Photos!
   / MX5100 shredding
i have 1 bad falt i never take the camera with me.
2019 FORD F-150 XL SINGLE CAB TRUCK (A51406)
2019 FORD F-150 XL...
2016 BMW X5 SUV (A50324)
2016 BMW X5 SUV...
Agco 8200 Flex Grain Platform (A50514)
Agco 8200 Flex...
1000 gal Fuel Tank (A50514)
1000 gal Fuel Tank...
RURAL KING RK37 TRACTOR (A51243)
RURAL KING RK37...
2017 Caterpillar 326FL Hydraulic Excavator (A50322)
2017 Caterpillar...
