Mx5100 remotes. Questions.
   / Mx5100 remotes. Questions.
No luck finding a monoblock with 3-flaot spools, other than spec'ing one out through brand hydraulics to the tune of ~$430.
Called baileys. Called northern, called many places. Here are my options not counting plumbing from tractor to valve, PB to 3PH, or valve to tank, because that is gonna all be the same no matter which option I choose:
Option 1:
I can get a chief G series 3-spool mono that has 1 spool with float. And 2 that dont. -10 in/out ports and -08 work ports. $185 @ baileys
Would need 6 female 1/2" ISO 5675couplings with 2-way sleeve from motion industries and 6 dust caps....$125
6 hoses about 12-18" long to connect the couplers to the valve......$20ea........................................$120
6 ORB to JIC adapters to connect hoses to valve.....................$10 total.
Option 1 total: $440 + shipping on parts + supply,PB, and return from valve
***Only has 1 float valve. But is a nice small 10gpm valve monoblock
Option 2:
Chief PC100 stackable valve from baileys:
3 Float work sections @ $83ea, Inlet section $24, outlet w/PB $25, Bolt kit $8.......Valve total $306
Same 6 hoses and JIC adapters....................................................................$130
Couplings..............................................................$125
Option 2 total $561 + shipping on parts + supply,PB, and return from valve
****What I dont like about this is the inlet/outlet are -12 and work ports are -10, since its a 21GPM valve. I worry about size being an issue, as well as trying to slowly control/feather the hydraulics with this big 21gpm valve
Option 3:
Prince SV series valve from baileys
3 float work sections $110ea, inlet section $47, outlet section w/PB $65, Bolt kit $14.....total valve.....$456
Same hoses and adapters............................................$130
Couplers....................$125
Total for option 3 $711 + shipping on parts + supply,PB, and return from valve
****I like that this is a smaller valve with -08 work ports and 10gpm flow, but dont like the cost. I'd probably order a monoblock from brand hydraulics with 3-flaot spools before I went this route.
Option 4: Order one of these Fasse Remote Master Hydraulic Tripler Valve Kit 7-13 for $475
Get a single spool float valve ~$100 many places
Plumb the 2 hoses to the from the fasse block , then 6 hoses $130 + 6 couplers $125 out the back
Option 4 total.........$830
**would require a few extra fittings and hoses to plumb the single spool valve to the fasse
Option 5: Just go all out and get Fasse 2 GPM ISO Hydraulic Tripler Remote Valve Kit with Command Stick $875
Still need a single spool valve ~$100
And would only need 2 hoses to go from valve to tripler block....$40
Wouldnt need any couplers as this comes with them. Mount the smart joystick to the single spool valve.
Option 5 total: $1015
***This would be a real slick setup, but have a hard time justifying the cost. Especially since I dont even have anything for the remotes to control at the moment.
Option 6: same as above, but waiting on a quote for this Wetherell Manufacturing Co. :: Made in the U.S.A.
Since I am a tight @$$ I'll probably just go with option 1 and live with 1 float valve. I really dont ever seen needing to float 2 at the same time. But If I were to ever get a TNT setup, they would likely always remained hooked up. If mowing and I want TL float.....okay. If grading and I now want optional side link float....I can just swap the couplers. Anyone have any examples of where you would need multiple floats on the SAME implement?
Option 7 That I am currently mulling over..
Get two of these SAE 8 15 GPM DOUBLE SELECTOR VALVE 12 VDC P15544-1
+ ~$100 for a single spool float valve. Plumb it into these two blocks in parallel.
Would have to buy 4 rear sets...~$160.
Hoses to plumb from this block pair to rear remotes $175
So ~$790 for FOUR sets of remotes.
If I went this route, still trying to decide if I would just mount the couplers direct to the solenoid block.....or if I would still want to run a short piece of hose back to the couplers, that way I can make brackets and clamp mount by the sleeve to get 1-handed operation + breakaway.
Uggg.....The more research I do, the more options I keep coming up with and even more undecided.
The block I linked above......one of these SAE 8 15 GPM DOUBLE SELECTOR VALVE 12 VDC P15544-1 seem to be widely avaliable at many sources and pretty cheap.
Why is it that simply adding a 3 coil/valve makes the price jump extreme and almost impossible to find. Fasse and wetherell seem to be the only two sources I can find, and for just a block/coils with no couplers or switch box they are about 3x's the cost of a double block :mur: Just dont seem right.
And after looking at other options, the fasse and wetherell, seems with a small re-design, could either be made cheaper.....or made to do more with the same price. You only need 2 coils/valves to control 3 functions, and 3 coil/valves should be able to control 4. Because you could have a default passage through the block, allowing for 1 function with NONE of the valves are active/energized. Then activate 1 for a second function. So if you wanted a doubler, basically you would only need 1 coil, basically a simple selector valve. De-energized feeds 1 function, energized feeds the second. Just like a diverter valve for a FEL. Not trying to re-engineer whats currently out there, just think they could be made better.
So after doing more looking, and discovering products that I didnt know existed....I came across stackable selector valves.
Chief Stackable Solenoid & Manual Operated Circuit Selector Valves: 14 @ 345 PSI GPM, SAE 8 Port Size, 5 PSI, 22934
For $232 I could stack two of these together and get 3 functions. And all 3 could be controlled by a simple 3 position toggle switch. In the off (center position), and neither coil energized, I could control the first set of remotes. Toggle one way to energize the first coil and control the second set. Toggle the other way to energize the second coil and control the third remote.
And I am having a harder time than I thought trying to find an affordable single spool float valve with PB. I could have swore I ran across them before for ~$100...not much more than a basic 34-way-3pos. But right now it looks like my best option is the prince 1 SPOOL 8 GPM PRINCE MB11G5C1 DA FLOAT VALVE for $199
Add 6 female couplers for $120
Probably $200 in all the hoses and fittings I am gonna need
And for ~$750 I sould have a complete 3 remote setup, with a single control valve and a 3 pos toggle. All 3 having float.
Best part is if I need more, I can buy another diverter section for $116, another pair of couplers for $40, and a few more hoses and toggle. So $200 more ea for a 4th, 5th, etc.
2019 UTILITY VS2RA 53FT REEFER TRAILER (A52141)
2019 UTILITY VS2RA...
2018 CATERPILLAR 249D SKID STEER (A51242)
2018 CATERPILLAR...
2020 CATERPILLAR 259D3 SKID STEER (A51242)
2020 CATERPILLAR...
Caterpillar 730 Articulated Dump Truck (A49346)
Caterpillar 730...
UNUSED AGT SAII100 QUICK ATTACH PALLET FORKS (A51244)
UNUSED AGT SAII100...
2016 Dodge Caravan (A50324)
2016 Dodge Caravan...
