Loader mx5100 loader lift capacity
   / mx5100 loader lift capacity #11
I don't know if you said you did or not, but have you looked at Kioti or Mahindra.. both lines have some very strong loaders in tractors that would be at or under the price of the MX. DK40se with KL401 is at 2760 lbs at the pins and a hydro model is maybe $22500 (prices vary by region). And some of those Mahindra models are in that price range and have very strong loaders also. maybe that 5035 with the ML130 loader about 2700 lbs full height at the pins. That is one mean angry looking tractor:eek:.Not trying to talk you out of a 'bota, but just an idea.
James K0UA
I too like the specs and looks of the Mahindra 5035. Im just too nervous about parts availibility in the future and the only dealer in my area hasnt sold Mahindras much more than a year i think. Heck for stout looking tractor though and still in the back of my mind. Im still hoping one of you mx5100 owners on here can give me some feedback:)
   / mx5100 loader lift capacity #13
Here is the info directly from the link you posted:
Bucket used General Purpose - 73-in. (1850 mm)
Bucket weight, lb. (kg) 392 (178)
Lift capacity at full height, lb. (kg) ---
Measured at pivot (U) 3133 (1424)
Measured at 500 mm ahead of pivot (V) ---
Measured at 800 mm ahead of pivot (V) 1956 (889)
Lift capacity at 59 in. (1500 mm), lb. (kg) ---
Measured at pivot (W) 4008 (1822)
Measured at 500 mm ahead of pivot (X) ---
Measured at 800 mm ahead of pivot (X) 2891 (1314)
Boom breakout force, lbf (kgf) ---
Measured at pivot (Y) 5378 (2439)
Measured at 500 mm ahead of pivot (Z) ---
Measured at 800 mm ahead of pivot (Z) 3604 (1635)
Bucket rollback force capacity, lbf (kgf) ---
At maximum height (VV) 3877 (1759)
At 59-in. (1500-mm) lift height (XX) 5544 (2515)
At ground level line (ZZ) 3860 (1751)
Also, Kubota does rate the loader lift capacity at 1500mm lift height (59") in addition to the full height spec. With that said, Kubota doesn't as readily post this info as Deere does. Some Kubota models they post this in the spec sheets, others you have to look in the owners manual. For example, they post the 1500mm specs for the L4600, L3800/3200, but I haven't seen it in the specs for the Grand L's or the Mx4700/5100.
Not trying to argue with you, just giving the OP another option.
AH, you are correct. I was looking at the 5095M, 5D, and 5E limited series for my numbers.
I wonder why the regular ole' 5E is higher than the rest:confused2:
   / mx5100 loader lift capacity #14
I have a mx5100 and have to say is has impresses me! Add ballast to the rear and it is great I have done a lot of clearing with this tractor . It performed great I allso bale hay with it. Before the back tires were loaded I was a little concerned but after I am very pleased moved some very big logs with it. I run a Vermeer 6040 cutter 8ft a ten wheel rake and a Vermeer 504n silage round baler very happy with the combo
sounds like you use your MX like i will when i get it! That makes me more certain itll do what i want. It sure seems like the perfect size for snaking through the woods i work in. I skid out some good sized(24"+dbh) red oak and white oak blow down. My old ford 531(industrial 3600) can drag em pretty good but i need four wheel drive and a loader badly.
   / mx5100 loader lift capacity #16
I have tried to abuse it and use it! Lol it has done every thing I needed and more offset the back tires out one setting and load the tires and you should be happy another good thing is the kubota ins 250 deductible and no questions asked! I let a tree fall over it in the woods. Fell across and over the hood did 3300.00 in damage paid my 250.00 had it back in a week new hood and all ! A freind of mine bought a manhandra comparable size he was dragging a log and the tractor broke in half right in front of the seat and fell to the ground ! So far I have had no problems with the mx5100 and I would say I push it harder then most people push a tractor the new 5140 kubota is a heavier tractor with more bells and whistles around 5 grand more . But again I have pushed trees over cleared land hauled trees move and load round bales . I have added the three rear remotes , great add wish I would have done it earlier. I love the shuttle transmission it makes FEL work easy and quick. If I can answer any thing for you feel free to ask I will tell ya bad or good !
2019 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A59575)
2019 FREIGHTLINER...
UNUSED IRGC40 Battery Powered Mini Golf Cart (A55272)
UNUSED IRGC40...
2024 Suihe Storage Shelter (A56859)
2024 Suihe Storage...
2020 PETERBILT 567 (A58214)
2020 PETERBILT 567...
(1) HD 24ft Free Standing Corral Panel (A57453)
(1) HD 24ft Free...
MODEL 14C SCRAPER (A58214)
MODEL 14C SCRAPER...
