MX5100 HST HST noise
/ MX5100 HST HST noise #1
horses2
Westminster, Md
Kubota M471D
I have an MX5100 HST that has been very reliable. It has developed what seems to be a bearing noise when in mid range or high range. the noise doesnt occur when loaded at lower speeds and not at all in low range. the noise is different from the trans whine.
all fluids are changed on schedule, using Kubota filters and fluids.
Any thoughts or suggestions?
/ MX5100 HST HST noise #2
How many hours when you noticed noise? Are you running udt or sudt2?
update: the tractor has 178 hrs. I had changed the hyd filters and topped off the fluids per the owners manual. I had used UDT. After going thru some threads on fluids, I drained all the hyd fluid, changed filters again and this time used SUDT2. hard on the wallet, but the tractor loved it!! The trans has NO noise, and seems to run alot smoother.
the SUDT2 is hard on the wallet, but the tractor runs GREAT.
2019 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A59905)
2019 FREIGHTLINER...
KBH Tender (A61307)
KBH Tender (A61307)
2020 Hino 195 20ft. Electric Box Truck (A59230)
2020 Hino 195...
Mower King Brush Cutter (A53317)
Mower King Brush...
Tandem Axle Rear Truck Frame (A59230)
Tandem Axle Rear...
2009 MULTIQUIP 25KW GENERATOR (A55745)
2009 MULTIQUIP...
