MX5100. Got my stuff ordered for hydraulics
/ MX5100. Got my stuff ordered for hydraulics #1
LD1
Epic Contributor
Central Ohio
Kubota MX5100
After beating my head against the wall for the past week, trying to decide how to do the hydraulics. Stackable valve? monoblock, single valve + selectors, etc etc, I have finally ordered parts this morning.
There is literally a ton of different ways to skin this cat, so my decisions was based on a balance between cost and functionality.
I ordered a 3-spool valve, with first lever having float. I was wanting all of them to have float....but then I'm into a sectional valve and cost goes up quick. And only two reasons I can think to float in the back is TNT. And even then.....not both at the same time. So I can always swap hoses.
Along with this valve, I also got a 3x12 and a 3x6 cylinder to build a toplink out if, as well as a 12v selector/diverter valve for the FEL. I figure while I am at it, installing the 3 rear remotes, I mught as well set the front up for a grapple while I am at it.
Selector/diverter, two cylinders, and 3-spool valve + PB plug......................$618.51 delivered.
8 coupling pairs w/2-way sleeves, + 8 caps and plugs.................................$205.67 delivered.
1 cat II and two cat I ball eyes for TNT build......................................................$21.72 delivered.
Still need to decide what I am gonna do for a button for the diverter. Seen some nice homemade ones here, looking into shift-knobs with buttons as well. But really waiting for suregrip to open so I can call them and get some pricing.
So, I am up to $845.90 and will have everything needed except the hoses, fittings. I'll probably have about $200 in all that, IF I had to buy everything. I already have a shelf full of fittings and adapters and hose ends. But I'll wait til I get stuff mounted and measured then start planning hose routing/lengths, etc.
So $845, + hoses and fittings + figure out what I am gonna do about a button/joystick.........looks like I can take this tractor from ZERO accessory hydraulics, to triple remotes, with TNT, and front diverter and keep it under $1200:thumbsup:
/ MX5100. Got my stuff ordered for hydraulics #2
Where did you buy? Do you have part numbers? I'm considering doing the same on my b2601.
baileynet.com for the cylinders and valves
Agrisupply.com for the ball ends
hydraulicstore.com for the couplers
/ MX5100. Got my stuff ordered for hydraulics #4
Thank you. I'll be following your project.
As soon as the stuff shows up, I'll be getting started on it. So hopefully next week?
/ MX5100. Got my stuff ordered for hydraulics #6
Great project but after all is said and done you'll wish you just bought from the wholegoods book and spent the extra coin. You'll have so many hours in that by the time you are done you won't have saved much.
Good luck though I'm sure it will come out nice, Fred
I don't understand? Kubota oem remotes would cost me over 2k just for parts for a triple.
I'm saving over $800 and getting a front diverter, and TNT. Alot more for alot less.
So don't see how you say I won't have saved much?
And it's not gonna take much time to install. I am very familiar with hydraulic, machining, and fab work. This is what I do for a living. Be kinda silly if I didn't apply my skills to my own stuff
/ MX5100. Got my stuff ordered for hydraulics #8
I jumped the gun and didn't see the front and TNT.
Sorry, Fred
Sorry, Fred
No worries.
If I could get OEM setup for close to aftermarket price, I wouldnt go to all the trouble to re-invent the wheel. But OEM stuff isnt even in the same ballpark. Its somewhere around $600-800 per set of rears. ~$350 per valve, and about the same for the handle kit + coupler bank and hoses.
/ MX5100. Got my stuff ordered for hydraulics #10
I looked at kubota prices for mine. IIRC it was ~$600 for the 1st and ~$500 for each additional.
Yea, OEM aint cheap. Thus my decision to do my own design
/ MX5100. Got my stuff ordered for hydraulics #12
And the reason OEM is not cheaper is because they have always sold plenty of it and they can get it. There is no reason the OEM should cost that much. Some other manufactures charge half of that for the same thing. But people want it and pay it. And as long as people pay it, the price will stay high. Just like .22 rimfire cartridges. As long as people will pay $60 for a brick of .22 rimfire, there just isn't a reason to lower the price to closer to the manufacturing costs. It has become the normal price, just like OEM remotes.:)
/ MX5100. Got my stuff ordered for hydraulics #13
I think you made a good choice going with just one float. I often float the tilt on the rear blade when grading driveways, but so far I've never run into a situation where I wished I had a 2nd float valve. Looking forward to seeing your project.
Was wanting the second (or third) float as an option.......because its a 4th position. Its not like you "have" to use it. I'd rather have it and not use it than not have it and wish I did.
My thoughts for a second float were for sidelink. Like blading snow and wanting it to follow a contour or crown and not dig into whats below or leave snow. Or running something that has 4 gauge wheels, like a RFM, you could allow side-side float.
So I know for sure I want to have the ability to float both the top and side links. But made the decision to get a single float spool, because I cannot think of any instance where I would need to float BOTH AT THE SAME TIME. A single spool is only a minor inconvenience, in that I would just have to swap the hoses to put the float spool in control of whatever I need.
/ MX5100. Got my stuff ordered for hydraulics #15
The perfect choice for me would be 2 float and 1 that would stay in position so I could run say a woodsplitter. On the L3940 I always use the float for the upper link while grading with a box blade it's handy also using the wood chipper it gives me lots of ground clearance while transporting it to the job at hand.
My new Kioti 260 has 1 spring loaded and 1 that stays either way. You can't get a floater from Kioti at least what my dealer told me.
Upper link float works well with the 8 foot land plane too.
I like having the options on all the valves.
Fred
I decided I didnt want a detent. A second float would have been nice, or even all three, but would have added $200 to the build, as it would have pushed me either into a special order monoblock triple, or a stackable valve. A 3-spool valve with 1 float spool is a more common "off-the-shelf" valve, and thus a good bit cheaper.
My thinking for not wanting a detent, is that third spool is gonna be used most likely for a rear angle blade. Or anything else hydraulic I get aside from the TNT. Like hydraulic rippers on a box blade, or spool tilting on a tile trailer, or raise/lower of a dump trailer, raise/low of field implements like a disc, etc. No plans for a logsplitter. And when feathering the controls for angling a blade or similar, I dont want to be fighting the detent.
And if I ever do have a need for the detent, nothing a 99 cent bungy strap cannot solve. So my though was that its easier to work around NOT having the detent, than it is to work around it if it is NOT needed.
Just ordered this New Sure Grip Hydraulic Single Trigger Two Button Control Joystick Mod SG13M21 | eBay
Everything is supposed to arrive tomorrow except for the joystick that I just ordered. Just in time for me to have to go back to work for 4 days straight @12/hrs a day:mur:, so I doubt I'll have time to get much done til next week. But hopefully I'll have enough time to mock stuff up even if only temporary so I can start figuring on fittings and hoses.
So so far, the running tally is $880.90 And all I need is hoses and fittings.
But like I said with those, I have most of what I need already, just a matter of making up the hoses, and seeing which fittings I use. But in the interest of cost, I'll figure hose and fitting prices as if I had to order everything, either DHH or surplus center, etc. that way I can keep an accurate running tally in case others are interested in doing similar. But looks like I am gonna come in under the $1000 mark for 3 rear remotes (one with float), a FEL diverter with joystick, and a TNT setup.
True cost probably will end in the $1200 range if I had to buy all the hydraulic hoses and fittings.
Everything has arrived this morning. Looking forward to getting this project started. Unfortunately I don't know now if I'll make much headway this weekend. Gotta work tonight and the next 3. 12hr shifts. And currently on my way to the eye dr as the wife is getting LASIK done. Hopefully I'll have enough time when we get back, and before I go to work, to get the valve mount figured out so I can get all my hose lengths. My access to the crimper is through work, I just keep the stuff I frequently need on hand.
Hopefully by mid next week I'll have this all wrapped up
Pretty major setback that likely is gonna cost me a week's time.
I ordered these couplers from trausch dynamics
Product Index | Trausch Dynamics[catalog]=1&data[itemcode]=2286679
Listed as a 1/2" body size and 3/8 thread.
Since I was gonna run 3/8 hoses, and getting the 1/2" coupler with 3/8 thread instead of typical 1/2" thread just made sense.
Well....they are NOT 1/2" couplers. Error on their site.they won't be open again til Monday morning :mur:
Wish I had opened the package when it arrived instead of just now. Realized this when I was measuring the sleeve to make the clamp mount, and it was significantly less than the 1.5" spec I had seen online. That's when I realized it's only a 3/8 coupler.
/ MX5100. Got my stuff ordered for hydraulics #20
Sorry about the setback.
Looking forward to the build. Don't forget pictures.
