MX5100 FEL question
   / MX5100 FEL question #1
kacole
gaffney, sc
kubota mx5100
I have a mx5100 with loaded tires. I read post where people have to have loaded tires, wheel weights and a ballist box in order to keep there tires on the ground when using there FEL. On my tractor i've picked up full buckets of rock/gravel with no problem i've even tried to pick up tree root balls and maxed the loader out without lifting the rear tires off the ground. my question is 1. is my tractor just weighted a little different than there's 2. Is my FEL picking up to the max like it should?
   / MX5100 FEL question #2
The only way to know if your loader can pick up the max like it should is a pressure check. If the hydraulic system relieves at correct pressure you OK. Sometimes the relief valve is not set to correct PSI.
3pt ballast will lighten the load the front axle "sees"
   / MX5100 FEL question #3
The only way to know if your loader can pick up the max like it should is a pressure check. If the hydraulic system relieves at correct pressure you're OK. Sometimes the relief valve is not set to correct PSI.
   / MX5100 FEL question #4
What Zebrafive said, I have loaded tires and wheel weights and can get by with that doing loader work, but still put 1000 pounds or so on 3PH.
   / MX5100 FEL question #5
I have the mx 5100, also. Loaded tires with a landscape rake and I have managed to lift the back wheels rather easily. Not to mention my 300 plus lbs. I seriously think you should be able to lift the wheels with out a backhoe attached. View attachment 379100
thanks for the replys how do you go about checking the pressure what should it be reading
   / MX5100 FEL question #8
I read post where people have to have loaded tires, wheel weights and a ballist box in order to keep there tires on the ground when using there FEL. On my tractor I have picked up full buckets of rock/gravel with no problem i've even tried to pick up tree root balls and maxed the loader out without lifting the rear tires off the ground.
It is important to have a counter-balance on the Three Point Hitch when doing FEL work.
Counter-balance unloads stress from the front axle and steering components. Loaded tires do not.
Counter-balance will make the tractor more stable. When transporting a heavy load without a counter-balance it is too easy to drop a tire into a hole or rut and have the tractor roll over. Loaded rear tires help in this circumstance, but a Three Point Hitch mounted counter-balance (ballast) is more effective.
Driving down a slope, weight shifts to the front of the tractor. A max load stable on flat ground can lift the rear tires moving down a slope. (You do not need this experience. I had it once, working at a burn pile. )
Because Three Point mounted counter-balance is cantilevered behind the tractor it is more effective as ballast than the plain weight would lead you to think.
With a counter-balance on the Three Point hitch I expect those tree root balls you have struggled to lift in the bucket will come right up. Chain loads in the bucket when transporting so material will not shift.
Rollover Box Blade/counter-balance in photo is a little less than 600 pounds.
(The R4 tires on my L3560 are filled only with air.)
If you have an optional Heavy-Duty, Round-Back Bucket, it is essential to carry ballast on the Three Point Hitch.
   / MX5100 FEL question #9
If your MX 5100 can't lift the back wheels off the ground with no ballast, I'd say you definitely have a problem somewhere. When trying to pull fence posts with my loader, it's no trick to lift up the rear wheels, and this is with a pretty heavy built box blade hanging on the back and loaded tires.
One possible difference MAY be the QA on the loader, which I have. It puts the bucket about a foot further out front, increasing the leverage a little bit. Not having QA might improve the handling a bit.:2cents:
   / MX5100 FEL question #10
Drilling post holes with my MX5100 with an FEL mount auger, if I don't have some rear weight attached, the rear wheels sometimes come up when I go to pull the auger out if it catches on a rock, etc.
(10) 28' Continuous Fencing Panels (A50515)
(10) 28'...
2016 John Deere TS Gator Utility Cart (A48082)
2016 John Deere TS...
1042 (A50459)
1042 (A50459)
2017 Ford F-150 4x4 Crew Cab Pickup Truck (A50323)
2017 Ford F-150...
2007 CATERPILLAR 930G WHEEL LOADER (A51242)
2007 CATERPILLAR...
2019 KOMATSU WA380-8 LOADER (A51242)
2019 KOMATSU...
