mx5100 cutter capacity
   / mx5100 cutter capacity #1
abb
Fayetteville AR
JD 6403
Bought a mx5100 last year and so far it works great. This year I need to find the largest cutter that the mx5100 can safely pull. Looking at 10' cutters but curious if that is to big of a cutter. Any suggestions would greatly be appreciated.
   / mx5100 cutter capacity #2
I would say a 10ft is to much for your tractor. I would say a 6ft would be a good fit 7ft would be pushing it. For the 10ft you would need a bigger tractor
Appreciate the feedback. I currently have the mx5100 but losing the hay lease we have had i now need to keep up about 300 acres and was hoping i wouldn't have to upgrade the tractor. What size tractor would you recommend for a 15' batwing cutter, Just curious because it appears I need more tractor to keep up about 300 acres.
   / mx5100 cutter capacity #4
look at the min pto hp requirement of your selected implement, I'd add 5 hp, then look at the specs of the M series models. Probably 85 0r 9540 at least. wouldn't want to tackle 300 acres with an mx unless you have plenty of time to spare. a 15' spread is a lot to pull in addition to the pto hp requirement. good luck bb
   / mx5100 cutter capacity #5
Good time to look for an older 100 plus horsepower tractor.
Deere 331G (A50120)
Deere 331G (A50120)
2024 KMC 7406 (A53084)
New Edco Hand 8" Post Hole Digger (A50774)
New Edco Hand 8"...
2021 John Deere C450 (A50120)
2021 John Deere...
2015 Revere Shasta 27DB 5th Wheel Travel Trailer (A51694)
2015 Revere Shasta...
2000 PETERBILT 379 TANDEM AXLE SLEEPER (A52141)
2000 PETERBILT 379...
