MX4800 HST kill switch
/ MX4800 HST kill switch #1
Luke'sScreenName
Elite Member
Lakes Region, NH
Kubota MX4800 with BH-90X hoe; Hustler FastTrack 48; B3300SU (sold); 1969 Case 680B CK (sold)
Anyone know where the kill switch for the HST pedal is? The one that when paired with the seat or PTO switch then kills the engine. I looked for a pressure switch on the HST pedal linkage but there is nothing there. Is it in the ECU? Thanks.
/ MX4800 HST kill switch #2
I am not sure about the MX series, but on the L series it is below the steering wheel behind the lower part of the dash.
/ MX4800 HST kill switch #3
What are you trying to do, use the hot pedal when not in the seat? If you jumper the seat safety switch it will allow this. I don't know of a switch tied to the actual hst pedal.
No, I want to install an audible alarm when both the parking break and HST are engaged.
Is there an actual momentary switch? What would I be looking for?
/ MX4800 HST kill switch #6
go to the kubota website, choose parts, illustrated parts list, check the box to accept the terms, and then put in mx4800, and choose the hst model, then the electrical section, choose the drawing about b10600 switch sensor, steering..etc.. I think this is what you are looking for. It is all hidden way up in there behind the steering column.
You rock! I used to do this with my old Case 680 backhoe but I didn't think Kubota offered the diagrams and blowups online. Thanks for the tip. I will look tonight.
/ MX4800 HST kill switch #8
Your Welcome.. the descriptions of the switches aren't very good, kind of cryptic, but it may help you figure it out. Do a screen snip and print it out on paper, and take it with you to the tractor, to help locate things.
It's on the left side of the drive train below the differential lock pedal and kinda burried.
INSPECTION (A61166)
INSPECTION (A61166)
2017 Hino 155 16ft. Box Truck (A59230)
2017 Hino 155...
2025 RB66 66in Rock Bucket Skid Steer Attachment (A59228)
2025 RB66 66in...
2015 MACK GRANITE GU713 T/A DUMP TRUCK (A59823)
2015 MACK GRANITE...
2018 Ford F-150 4x4 Crew Cab Pickup Truck (A59230)
2018 Ford F-150...
Deere 50D (A60462)
Deere 50D (A60462)
