MX class 2 hitch
/ MX class 2 hitch #1
saray
chipley, fl
shopping
I'm considering buying the MX48 and would like to know can I still run my class one devices with a class 2 hitch?
/ MX class 2 hitch #3
YES you will need bushings for the cat 1 pins about 3 to 5 bucks each
/ MX class 2 hitch
Thanks was trying to decide btwn l4701 and mx4800 guess that answers it
/ MX class 2 hitch #5
I was looking at the same two tractors. My dealer did not have the MX4800 so I went with the MX5200 as it was only $1000 more than the MX4800. You can use the Cat 1 implements just have to use bushings to take up the difference at $2 each from tractor supply or change the pins to Cat 2. Since I have another tractor that uses only Cat 1 implements I just use the bushings. The adjustable ends are on the MX link arms are a must as it would be almost impossible connect equipment from the tractor seat.
/ MX class 2 hitch #6
I was told by my dealer that The MX4800 comes with the bushings as a stock item
Hope so cus I ordered an MX4800 and then upgraded to the MX5800
/ MX class 2 hitch #7
If not there only a couple $, Tell the dealer to throw them in plus a hat:D
/ MX class 2 hitch #8
My MX5800 came with bushings in the tool box. That was in November.
/ MX class 2 hitch #10
We have a MX5800. We installed Pat's quick connect system, using their option that fits the Class 2 MX lift-arm size and reduces it to a Class 1 o the hook-up end. We did this because all of our implements/attachments are Class 1. This set-up works great for us. If we ever want to go to Class 2--which is doubtful--we will use the bushings referred to above.
/ MX class 2 hitch #11
Same with my MX5200, but only one set. I bought a bunch from TSC, 2-3 dollars apiece. That way I just leave them on the pins, secured with lynch pins.
The convenience of a quick hitch disappears quickly if you have to dismount to switch over bushings.
/ MX class 2 hitch #12
Just got my MX5200 and it did come with one set of Cat1-to-Cat2 bushings. As mentioned it is easier to just leave them on each implement for a few dollars. Also, some implements required 2 bushings to cover the width of the pin area such as my LandPride rotary cutter. Some are narrow connections and only need one but I don't like the slop on the pin when it isn't the same diameter across the entire connection. Things start to round-off otherwise.
/ MX class 2 hitch #13
Ha! I originally started w/ an L3901 --> L4701 --> MX4800 --> MX5200 then to my final destination of MX5800! What a ride!
2022 CATERPILLAR 289D3 SKID STEER (A62129)
2022 CATERPILLAR...
429905 (A61165)
429905 (A61165)
PORTABLE SAND BLASTER (A62131)
PORTABLE SAND...
RoGator RG1100C (A63118)
RoGator RG1100C...
Kubota L3901HST
Kubota L3901HST
2020 CATERPILLAR 249D3 SKID STEER (A62129)
2020 CATERPILLAR...
