MX class 2 hitch
/ MX class 2 hitch #1
saray
chipley, fl
shopping
I'm considering buying the MX48 and would like to know can I still run my class one devices with a class 2 hitch?
/ MX class 2 hitch #3
YES you will need bushings for the cat 1 pins about 3 to 5 bucks each
/ MX class 2 hitch
Thanks was trying to decide btwn l4701 and mx4800 guess that answers it
/ MX class 2 hitch #5
I was looking at the same two tractors. My dealer did not have the MX4800 so I went with the MX5200 as it was only $1000 more than the MX4800. You can use the Cat 1 implements just have to use bushings to take up the difference at $2 each from tractor supply or change the pins to Cat 2. Since I have another tractor that uses only Cat 1 implements I just use the bushings. The adjustable ends are on the MX link arms are a must as it would be almost impossible connect equipment from the tractor seat.
/ MX class 2 hitch #6
I was told by my dealer that The MX4800 comes with the bushings as a stock item
Hope so cus I ordered an MX4800 and then upgraded to the MX5800
/ MX class 2 hitch #7
If not there only a couple $, Tell the dealer to throw them in plus a hat:D
/ MX class 2 hitch #8
My MX5800 came with bushings in the tool box. That was in November.
/ MX class 2 hitch #10
We have a MX5800. We installed Pat's quick connect system, using their option that fits the Class 2 MX lift-arm size and reduces it to a Class 1 o the hook-up end. We did this because all of our implements/attachments are Class 1. This set-up works great for us. If we ever want to go to Class 2--which is doubtful--we will use the bushings referred to above.
/ MX class 2 hitch #11
Same with my MX5200, but only one set. I bought a bunch from TSC, 2-3 dollars apiece. That way I just leave them on the pins, secured with lynch pins.
The convenience of a quick hitch disappears quickly if you have to dismount to switch over bushings.
/ MX class 2 hitch #12
Just got my MX5200 and it did come with one set of Cat1-to-Cat2 bushings. As mentioned it is easier to just leave them on each implement for a few dollars. Also, some implements required 2 bushings to cover the width of the pin area such as my LandPride rotary cutter. Some are narrow connections and only need one but I don't like the slop on the pin when it isn't the same diameter across the entire connection. Things start to round-off otherwise.
/ MX class 2 hitch #13
Ha! I originally started w/ an L3901 --> L4701 --> MX4800 --> MX5200 then to my final destination of MX5800! What a ride!
12 Ton Hydraulic Bottle Jack (A61567)
12 Ton Hydraulic...
UNUSED KJ 20'X12' LIVESTOCK METAL SHED (A62131)
UNUSED KJ 20'X12'...
(2) UNUSED 25X8.50-14 TIRES W/6 LUG RIMS (A62130)
(2) UNUSED...
2018 Ford F-150 4x4 Ext. Cab Pickup Truck (A61568)
2018 Ford F-150...
NEW HOLLAND TS115A TRACTOR (A62130)
NEW HOLLAND TS115A...
208315 (A58376)
208315 (A58376)
