MX class 2 hitch
   / MX class 2 hitch #11
My MX5800 came with bushings in the tool box. That was in November.
Same with my MX5200, but only one set. I bought a bunch from TSC, 2-3 dollars apiece. That way I just leave them on the pins, secured with lynch pins.
The convenience of a quick hitch disappears quickly if you have to dismount to switch over bushings.
   / MX class 2 hitch #12
Just got my MX5200 and it did come with one set of Cat1-to-Cat2 bushings. As mentioned it is easier to just leave them on each implement for a few dollars. Also, some implements required 2 bushings to cover the width of the pin area such as my LandPride rotary cutter. Some are narrow connections and only need one but I don't like the slop on the pin when it isn't the same diameter across the entire connection. Things start to round-off otherwise.
   / MX class 2 hitch #13
I was told by my dealer that The MX4800 comes with the bushings as a stock item
Hope so cus I ordered an MX4800 and then upgraded to the MX5800
Ha! I originally started w/ an L3901 --> L4701 --> MX4800 --> MX5200 then to my final destination of MX5800! What a ride!
   / MX class 2 hitch #14
2015 FREIGHTLINER CASCADIA (A50854)
2015 FREIGHTLINER...
2019 FORD F-150 XL SINGLE CAB TRUCK (A51406)
2019 FORD F-150 XL...
2025 Safety Basket Forklift Attachment (A50322)
2025 Safety Basket...
2007 FORD F-450 (A50854)
2007 FORD F-450...
2004 CATERPILLAR 140H MOTORGRADER (A51406)
2004 CATERPILLAR...
5th Wheel Dolly (A49461)
5th Wheel Dolly...
