MX class 2 hitch
   / MX class 2 hitch #1
saray
chipley, fl
shopping
I'm considering buying the MX48 and would like to know can I still run my class one devices with a class 2 hitch?
   / MX class 2 hitch #3
YES you will need bushings for the cat 1 pins about 3 to 5 bucks each
   / MX class 2 hitch
Thanks was trying to decide btwn l4701 and mx4800 guess that answers it
   / MX class 2 hitch #5
I was looking at the same two tractors. My dealer did not have the MX4800 so I went with the MX5200 as it was only $1000 more than the MX4800. You can use the Cat 1 implements just have to use bushings to take up the difference at $2 each from tractor supply or change the pins to Cat 2. Since I have another tractor that uses only Cat 1 implements I just use the bushings. The adjustable ends are on the MX link arms are a must as it would be almost impossible connect equipment from the tractor seat.
   / MX class 2 hitch #6
I was told by my dealer that The MX4800 comes with the bushings as a stock item
Hope so cus I ordered an MX4800 and then upgraded to the MX5800
   / MX class 2 hitch #7
If not there only a couple $, Tell the dealer to throw them in plus a hat:D
   / MX class 2 hitch #8
My MX5800 came with bushings in the tool box. That was in November.
   / MX class 2 hitch #9
My MX5100 came with bushings in 2011..:thumbsup:
HP
   / MX class 2 hitch #10
We have a MX5800. We installed Pat's quick connect system, using their option that fits the Class 2 MX lift-arm size and reduces it to a Class 1 o the hook-up end. We did this because all of our implements/attachments are Class 1. This set-up works great for us. If we ever want to go to Class 2--which is doubtful--we will use the bushings referred to above.
CATERPILLAR 259D3 SKID STEER (A50458)
CATERPILLAR 259D3...
PAIR OF PIPE RACKS (A50854)
PAIR OF PIPE RACKS...
2007 STERLING TRUCK ASPHALT DISTRIBUTOR (A50854)
2007 STERLING...
2008 RIB 24 Cat Boat (A50324)
2008 RIB 24 Cat...
Ingersoll Rand 185 Towable Diesel Air Compressor (A49461)
Ingersoll Rand 185...
PENDING SELLER CONFIRMATIONS (A51219)
PENDING SELLER...
