mx 5100 remotes
/ mx 5100 remotes #1
candyman
oh
Kubota 2011 MX5100 W/la844 loader, ag/ tires loaded, Massey Ferguson 2010 GC2610 TLB w/ r4 tires, loaded, 60" Belly Mower
has anyone installed rear remotes. i do not have any but would like to install 4.
2 for the top&tilt & 2 for the angle.
can anyone tell me what to get & how to install them.
dealer wants way to much.
thanks
/ mx 5100 remotes #2
This is what I did on my L3400. You'll have more space to work with, but if you're adding 4 sets of remotes, which is 8 connections, you're going to be pressed for room as well. I think you meant 4 connections (2 sets), but the process is the same regardless.
http://www.tractorbynet.com/forums/hydraulics/188519-adding-rear-remote-kubota-l3400.html
You might want to consider using a stackable valve body, and not a monoblock style like I used. The stackable leaves room to expand.
Be sure your directional valve includes a pressure relief, that lets you customize the pressure at the remotes to suit your needs.
Routing the hoses so they're out of the way can be tricky too, unless you're inclined to bend and fit hard pipes. I used all hoses, no problems so far.
By the time you're finished, the dealer option of a factory kit might not look so expensive. Mine cost me almost $700 by the time I was finished. The valve, hoses, fittings and adapters all add up.
Sean
/ mx 5100 remotes #3
I just did the install on my tractor for 2 sets. Do a search and u can see them.
/ mx 5100 remotes
thanks chiily & orange toys for the info.
orange toys, what do you mean by one is detent & one is float. ? did you but the kit from a dealer complete & just install it per directions. was there any misc. parts you had to buy.
cm
/ mx 5100 remotes #6
I believe the maximum for the Kubota brand rear remotes is three on an MX5100. I bought one set when I purchased my tractor as I heard that was the more difficult one to install. After that it's stacking on the first from what I understand.
HP
/ mx 5100 remotes #7
cm
Yes I bought the whole kit and followed the directions. We got it installed in about 2.5-3hrs. Everything you'll need comes in the kit. 3 remotes is Max. I can't explain the float and detent that great hopefully someone will jump in. Or just search it on here I saw a few threads.
/ mx 5100 remotes #8
yes the installed valves are costly.but if you install them yourself,an you mess up doing it.it wouldve been cheaper to let the dealer do it.
/ mx 5100 remotes
orange toys,
what have you hooked to your remotes & how are they working.
cm
/ mx 5100 remotes
orange toys,
do you have any close up pix of your remote install.
cm
/ mx 5100 remotes #11
candyman said:
orange toys,
cm
I've had no issues at all. I just have a top link hooked in right now and ill be adding a cylinder to a rear blade soon.
What kind of pics do you want? I thought I had everything posted already.
/ mx 5100 remotes #12
If the MX5100 is anything like my L5740 it should be a very easy install. I did mine in a couple of hours. Just be careful with the O-rings that they don't get out of place before things are bolted together.:thumbsup:
/ mx 5100 remotes #13
Check out purchasing the 3 factory Kubota valve kits and install them yourself. Then put an electric divert-er valve on one of the factory valves for the 4Th unit. Relatively quick, and makes for the cleanest install.
I would be sure to get at least one of the remotes with float position, you will want it for your tilt cylinder of the top and tilt kit. ;)
/ mx 5100 remotes
orange toys, i got the pix. thanks
mvr, what do you mean diverter valve, please xplain, i`m lost. when this is all said & done i`ll be getting the top & side units from you.
thanks, cm
/ mx 5100 remotes #15
The diverter valve switches the output from one of the spool valves to a different set of hoses/quick connects.
In other words, if you have a three spool valve and one diverter, you have enough outputs for 4 sets of remotes simply by switching the diverter to the alternate position. Keep in mind that you have to switch the diverter between the two sets of remotes, both won't work at the same time.
I think there are diverters that are capable of handling more than 1 set of connections, I haven't looked at them personally.
I may be wrong on this, but that's the way I understand it.
/ mx 5100 remotes #16
I have an MX5100 that I would like to add a set or two of rear remotes. Would anyone here have the Kubota kit number for the parts? Thanks!
Curtis
/ mx 5100 remotes #17
Curtis
Curtis,
Go to the Messick's web site and pull up the parts document for Kubota-MX5100DT-"OPTIONS" . It will list all the individual parts. I'm not sure what the "Kit" numbers are but if you call them, they'll be able to help.
HP
2021 TAKEUCHI TL6R SKID STEER (A65053)
2021 TAKEUCHI TL6R...
2016 Kubota SSV75 Compact Wheel Loader Skid Steer (A64553)
2016 Kubota SSV75...
2009 Case CX240B Excavator (A64194)
2009 Case CX240B...
2014 John Deere 350G Hydraulic Excavator (A64194)
2014 John Deere...
2013 KENWORTH T370 DUMP TRUCK (A65054)
2013 KENWORTH T370...
2007 Western Star 4900 SA Tri-Axle Wet Kit Day Cab Truck Tractor (A61573)
2007 Western Star...
