MX 5100 leak from hydraulic plug?
/ MX 5100 leak from hydraulic plug? #1
cre73
Central Illinois
Kubota B2601
A friend brought their 5100 out to our lake lot and it is dripping pretty constantly from a plug located about dead center of the tractor approximately 16in from the back of the oil pan. This plug has some sort of stem that you can push up and down. When pushed up the drip stops. What are we dealing with? Thanks
/ MX 5100 leak from hydraulic plug? #2
On the L3400 it is called the “Split Pin Plug”.... for draining clutch housing water....
/ MX 5100 leak from hydraulic plug? #4
The pin rattles around to prevent & clear obstructions. If noticable fluid is comming out of it there is a problem. If its black, you have a rear main seal leak on the engine. If its reasonably clear your input shaft seal on the teanny is leaking. You need to split the tractor to replace the tranny seal. Likely need to split for the engine rear main seal. If there is much oil in there you'll need to replace a contaminated clutch disk.
JOHN DEERE 5055E TRACTOR (A64280)
JOHN DEERE 5055E...
2018 Navigator RT-6500 6,500lb Piggyback Forklift (A61567)
2018 Navigator...
2007 Komatsu WA200-5 (A64047)
2007 Komatsu...
2011 Freightliner B2 School Bus (A61573)
2011 Freightliner...
UNUSED WOLVERINE 3PT QUICK TACH (A64281)
UNUSED WOLVERINE...
2018 ALLMAND MP40-8B1 PORTABLE (3) PHASE GENERATOR (A63276)
2018 ALLMAND...
