MX 5100 leak from hydraulic plug?
/ MX 5100 leak from hydraulic plug? #1
cre73
Central Illinois
Kubota B2601
A friend brought their 5100 out to our lake lot and it is dripping pretty constantly from a plug located about dead center of the tractor approximately 16in from the back of the oil pan. This plug has some sort of stem that you can push up and down. When pushed up the drip stops. What are we dealing with? Thanks
/ MX 5100 leak from hydraulic plug? #2
On the L3400 it is called the “Split Pin Plug”.... for draining clutch housing water....
/ MX 5100 leak from hydraulic plug? #4
The pin rattles around to prevent & clear obstructions. If noticable fluid is comming out of it there is a problem. If its black, you have a rear main seal leak on the engine. If its reasonably clear your input shaft seal on the teanny is leaking. You need to split the tractor to replace the tranny seal. Likely need to split for the engine rear main seal. If there is much oil in there you'll need to replace a contaminated clutch disk.
1992 21ft Four Winns 205 Sundowner Boat w/ Boat Trailer (A61574)
1992 21ft Four...
JOHN DEERE 1520 - 15' GRAIN DRILL (A63291)
JOHN DEERE 1520 -...
2019 Ford Transit 350 Police Transport Van (A61573)
2019 Ford Transit...
Kenworth T6 (A63688)
2007 Cadillac DTS Sedan (A61574)
2007 Cadillac DTS...
2021 BOBCAT T62 R-SERIES SKID STEER (A64279)
2021 BOBCAT T62...
