MX 5100 DT vs. Kubota L4400 HST
   / MX 5100 DT vs. Kubota L4400 HST #1
ids
Hello,
I was wondering if anyone might have an opinion on these two tractors. The price is roughly the same, (~240000), but the 44 is HST where the 5100 DT is gear driven - .
.I was just wondering is that the only difference? Is the HST just that much better? I was wondering what the DT meant..
Thanks
Steve
P.S. sorry for posting this is 2 threads, wasn't sure which one was more appropriate
   / MX 5100 DT vs. Kubota L4400 HST #2
DT means 4wd, I'd go with the MX. JMO. The MX probably has the shuttle shift...sweet.
Rob
Actually, it does have "shuttle shift"...can you tell me what that means?
thanks
   / MX 5100 DT vs. Kubota L4400 HST #4
thanks
Basically you put it in the gear of your choice. 1,2,3,4, etc, then the shuttle positions are forward, neutral, reverse. So forward to go forward into a pile with the fel, the pull the shuttle to reverse to back out. Most I think you do not have to clutch to do this, just back off the throttle to make it a bit easier on the tractor.
I like the position of them on some backhoes I've rented, on the steering column.
Good Luck,
Rob
   / MX 5100 DT vs. Kubota L4400 HST #5
This same discussion is going on in the Buying/Pricing forum and some good point have been made. You might want to read that post too.
PORTABLE METAL FUEL TANK (A51243)
PORTABLE METAL...
2008 Ford F-250 4x4 Service Truck with Liftgate (A50323)
2008 Ford F-250...
2007 FORD F-750XL SUPER DUTY DUMP TRUCK (A51243)
2007 FORD F-750XL...
377780 (A48837)
377780 (A48837)
TAKEUCHI TB290 EXCAVATOR (A51242)
TAKEUCHI TB290...
2015 Freightliner Cab & Chassis (A47384)
2015 Freightliner...
