MX 5100 DT vs. Kubota L4400 HST
   / MX 5100 DT vs. Kubota L4400 HST #1
ids
Member
Hello,
I was wondering if anyone might have an opinion on these two tractors. The price is roughly the same, (~240000), but the 44 is HST where the 5100 DT is gear driven - .
.I was just wondering is that the only difference? Is the HST just that much better? I was wondering what the DT meant..
Thanks
Steve
P.S. sorry for posting this is 2 threads, wasn't sure which one was more appropriate
   / MX 5100 DT vs. Kubota L4400 HST #2
DT means 4wd, I'd go with the MX. JMO. The MX probably has the shuttle shift...sweet.
Rob
Actually, it does have "shuttle shift"...can you tell me what that means?
thanks
   / MX 5100 DT vs. Kubota L4400 HST #4
thanks
Basically you put it in the gear of your choice. 1,2,3,4, etc, then the shuttle positions are forward, neutral, reverse. So forward to go forward into a pile with the fel, the pull the shuttle to reverse to back out. Most I think you do not have to clutch to do this, just back off the throttle to make it a bit easier on the tractor.
I like the position of them on some backhoes I've rented, on the steering column.
Good Luck,
Rob
   / MX 5100 DT vs. Kubota L4400 HST #5
This same discussion is going on in the Buying/Pricing forum and some good point have been made. You might want to read that post too.
2016 John Deere TS Gator Utility Cart (A48082)
2016 John Deere TS...
2017 MACK CHU613 TANDEM AXLE SLEEPER (A51222)
2017 MACK CHU613...
2003 International 4300 Flatbed Truck w/ Liftgate - Inoperable - 7.6L DT466 Diesel Engine (A51039)
2003 International...
2021 Doyle 8 Ton Trailer Tender (A51039)
2021 Doyle 8 Ton...
2022 CATERPILLAR D4 LGP CRAWLER DOZER (A51242)
2022 CATERPILLAR...
2014 UTILITY 53X102 DRY VAN TRAILER (A51222)
2014 UTILITY...
