MX 170 PTO fault code
/ MX 170 PTO fault code #1
stacas
Macon, MO
Case
I have a MX 170 and there is a fault code 63 with my pto. Does anyone know what this means. Thanks
/ MX 170 PTO fault code #2
Speed sensor would be the start of the problem. You could have an issue with the PTO as far as slippage that would also cause the problem if not up to speed in six seconds.
/ MX 170 PTO fault code #3
Hello,
I have an '2000 Case MX 100 and the pto doesn't work. It start and after 5 sec stops. The tractor returns error code 67. Does anybody know, for what this code stand for?
Best regards!
/ MX 170 PTO fault code #4
More than likely its not sensing speed of the PTo shaft, so yes I'd check sensor first.
2021 Mercedes-Benz Sprinter 4500 Modified Food Catering Van (A61573)
2021 Mercedes-Benz...
2022 EZ-GO ELITE...
2015 ALTEC AT200 MOUNTED ON 2015 FORD F450 XL SD (A67148)
2015 ALTEC AT200...
2021 DITCH WITCH HX30 TOWABLE VACUUM TRAILER (A63276)
2021 DITCH WITCH...
UNUSED PARBREAK RT260-72" HYD ROTARY TILLER (A65055)
UNUSED PARBREAK...
2634 (A65055)
2634 (A65055)
