Multirotors / Quadcopters / otherwise known a DRONES
   / Multirotors / Quadcopters / otherwise known a DRONES #41
Robert Gibson published a series of sci if novels beginning in 1984 with Neuromancer. Drones following and even attacking people were part of several of his novels.
It was in that novel that he coined the term cyberspace.
   / Multirotors / Quadcopters / otherwise known a DRONES #42
There have been TBN threads on how to make a straight line between property corners that have a hill between them so you cannot see one point from the other.
Now, just have a quadcopter hover over one high enough that it can be seen and no more problem! Straight line. :)
I'm facing this issue right now and I think this could be my answer. Put a laser on a tripod, align from one property marker to the quadcopter. How long the quadcopter can stay airborne then doesn't matter, you can use the stationary laser to mark each fence post.
Regular off the shelf units can stay up for about 15minutes. I think the issue would be having a good GPS fix. Even the slightest wind will move these things around just a little and that is a little too much if you are trying to mark out property lines. Also on most of the GPS units they say to give your waypoints at least a 5' circle so the quad will not spend lots of time "hunting" for just that one spot before it goes to the next waypoint.
Larger units can carry larger batteries, these with the camera gear can stay in the air for over 30 minutes....up to an hour with very light loads.
Hope that answered your question.
   / Multirotors / Quadcopters / otherwise known a DRONES #44
We joke about this under wing seeder/fertilizer as the' FLUZ CAPACITOR' from the movie Back to the Future. :)
   / Multirotors / Quadcopters / otherwise known a DRONES #45
UAV's are going to be standard fare at your local tractor dealer in not too long. There are LOADS of applications for these things in agriculture.
   / Multirotors / Quadcopters / otherwise known a DRONES #46
got a flyer from Rural King with advertising for multirotors
   / Multirotors / Quadcopters / otherwise known a DRONES #47
I went to the National Farm Equipment Show in Louisville, KY back in February. There were several vendor booths there displaying UAV's.
   / Multirotors / Quadcopters / otherwise known a DRONES #48
In many instances that could be an issue. For me I was going to have my brother standing at one property marker and operate the quad so it is directly above him. We'll be on the phone to each other and when he says 'now' then I set the laser direction. No GPS involved. :cool:
   / Multirotors / Quadcopters / otherwise known a DRONES #49
How will he determine that it is directly overhead?
2019 GALYEAN EQUIPMENT CO. 150BBL STEEL (A58214)
2019 GALYEAN...
Brown Metal Roof Panels (A55758)
Brown Metal Roof...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2004 EAGER BEAVER 50GSL/3 DETACH TRAILER (A52707)
2004 EAGER BEAVER...
2013 CIMC REEFER TRAILER (A58018)
2013 CIMC REEFER...
500 Gallon Fuel Tank with Pump (A55853)
500 Gallon Fuel...
