Multiple threads no clear answer CK/X2510 engine vs CK2610
   / Multiple threads no clear answer CK/X2510 engine vs CK2610 #21
Now I need to check my CX engine tag and see if it is also uses the larger displacement engine, the owners manual states it has the 3A165LWH-U3, 1647cc/87cu and for kicks I ran the 1647 through cubic inch converter and it states 100.5 not 87 as the manual states.
I had investigated the smaller engine at time of purchase and found they had used it in a 27 or 28 hp machine and figured if I needed more power I could turn it up a bit. This info makes me think it can be turned up alot. Seems I remember a Kubota model they were turning up as the engine was derated but was used in a higher hp application.
2006 GMC W3500 Truck, VIN # J8DB4B16867021673 (A57453)
2006 GMC W3500...
LOT: (8) Wheel Loader Bucket Teeth (A59076)
LOT: (8) Wheel...
Deere 60G Mini Excavator (A57148)
Deere 60G Mini...
2013 Ford F-250 Crew Cab Pickup Truck (A56858)
2013 Ford F-250...
KNOW BEFORE YOU BID - DO YOUR HOMEWORK AND BE HAPPY WITH YOUR PURCHASE (A58375)
KNOW BEFORE YOU...
LOT: (3) Shelves of Parts, Filters, Oil, Antifreeze (CONTENTS ONLY - ALL APPEAR TO BE UNOPENED) (A59076)
LOT: (3) Shelves...
