Multi ripper attachment
/ Multi ripper attachment #11
Barryh said:
I took the truck into town and had someone help me load this 300 pound tree trunk into the back. I do rustic wood working, and plan to make a table out of this for my down stairs.
I used the PT, and forks to lift it out of the truck. I had to rest it against this tree to keep the the hydraulic bleed off from letting it down... while I took the picture. It's hard to tell from this picture the size of this thing, but I can tell you first hand it's really heavy.
Do you think the ripper could be rigged up so that it will dig along the tire line or offset? This would be very helpful in tight areas such as fench line.
PJ
PJ
Sure you could, would just be a matter of mating the right hitch tube with the right hitch elbow they make all kinds and angles. If you look at the picture on my second post of this thread you can see one setting on the work table I bought, that could be used for off set of the main tube.
You could probably use your fork like I did and mount it off to one side, but I'm not sure how strong the weld on the fork is for this kind of continued use.
As I said, I plan on having mine welded to one of my attachment plates. I bought most of my tubing, and hitches from Northern Tool.
Here is a guy who sells on Ebay. He makes attachments that clip on to your bucket a little exspensive but, very handy.
You would have a convenient way to clean out along a fence line by just attaching to your LMB or your Rock bucket. Link below.
eBay Store - Ground Works: Category 4, Category 1
Scroll down to the (Trencher sod cutter)
Then scroll down to the (Tractor hitch bucket hitch multi-function 2in rec)
/ Multi ripper attachment #13
Thanks, this is something I have wanted and will sure look into.
PJ
PJ
Not a problem, just a few other ideas. I will be using mine with an optional shorter tube, the longer one will be for more of a boom and tree skidder.
I'll also be making other attachments such as a plug in broom for my driveway, rock rake, winch, hitch and will be looking for material to make more of a scoop to go with the ripper for cleaning shallow trenches.Since I don't have a mini hoe yet, it may also serve as a light digging tool.
PJ
pajoube,
just as an added note, if you’re thinking about making your own. I bought the ripper tooth which I think is just a box blade tine for a tractor 3 point, at Tractor supply. If you have one near you.
The clevis mount to attach it to, from Northern Tool. I had to drill through the end of the tube so it would mount upright. If you have welding equipment I’m sure you could do all of this much cheaper.
I added another attachment that seems pretty handy. I used a shorter tube this time and made a trench maker/cleaner to go with my ripper attachment.
For now, I am still using the forks as a base for testing these. I decided to go ahead and just dig up this stump by the driveway. I'm real tired of looking at it. A few pictures of the work, and trencher. First one of the trencher/digger.
Another shot. I used # 8 grade bolts which seems to be over kill.
Digging around the stump.
Another.
Last one of attachment and 24 inch tube. I also used this to dig a trench and bury some cable going to an outside yard light I made.
Ford 8340 (A53317)
Ford 8340 (A53317)
SKID STEER ATTACHMENT CEMENT MIXER (A58214)
SKID STEER...
2021 FORD F-150 STX CREW CAB TRUCK (A59823)
2021 FORD F-150...
UNKNOWN  20 FLATBED GOOSENECK (A58214)
UNKNOWN 20...
2000 GMC C7500 (A60736)
2000 GMC C7500...
iDrive TDS-2010H...
