multi power on 35x stuck in low
   / multi power on 35x stuck in low #1
peter1956
Multi power on 35xstuck in low
   / multi power on 35x stuck in low #2
Multipower operates via a hydraulic clutch, doubles the number of gears (6F/2R to 12F/4R) and stuck in low is the common failure mode. YOu can still use the tractor but there's no engine braking or hill holding capability (available only in MP "high" range). To fix the MP unit you have to split the tractor to remove the unit. Parts are expensive.
Good luck.
CFG MH12RX Mini Excavator (A49461)
CFG MH12RX Mini...
2018 Toro Workman GTX Electric Utility Cart (A51691)
2018 Toro Workman...
Roller (A52377)
Roller (A52377)
2025 K0720 UNUSED Metal Farm Driveway Gate Set (A53117)
2025 K0720 UNUSED...
MANITOWOC QD08902A ICE MAKER (A51248)
MANITOWOC QD08902A...
DEUTZ-FAHR 5110G TRACTOR (A51247)
DEUTZ-FAHR 5110G...
