multi power on 35x stuck in low
   / multi power on 35x stuck in low #1
peter1956
Multi power on 35xstuck in low
   / multi power on 35x stuck in low #2
Multipower operates via a hydraulic clutch, doubles the number of gears (6F/2R to 12F/4R) and stuck in low is the common failure mode. YOu can still use the tractor but there's no engine braking or hill holding capability (available only in MP "high" range). To fix the MP unit you have to split the tractor to remove the unit. Parts are expensive.
Good luck.
2023 JACTO JATAO-1000 LOT IDENTIFIER 262 (A53084)
2023 JACTO...
Electric Mobility Scooter (A51694)
Electric Mobility...
1996 Trailmobile 53 ft. Dry Van Trailer (A53117)
1996 Trailmobile...
2019 Autocar Xspotter Truck (A52384)
2019 Autocar...
2025 SDLANCH IRGC40 UNUSED Electric Tricycle (A53117)
2025 SDLANCH...
2006 Peterbilt 335 Day Cab Truck (A53117)
2006 Peterbilt 335...
