multi power on 35x stuck in low
   / multi power on 35x stuck in low #1
peter1956
Multi power on 35xstuck in low
   / multi power on 35x stuck in low #2
Multipower operates via a hydraulic clutch, doubles the number of gears (6F/2R to 12F/4R) and stuck in low is the common failure mode. YOu can still use the tractor but there's no engine braking or hill holding capability (available only in MP "high" range). To fix the MP unit you have to split the tractor to remove the unit. Parts are expensive.
Good luck.
UNUSED WOLVERINE TCR-12-48H 48" HYD TRENCHER (A51248)
UNUSED WOLVERINE...
Billy Goat Blower Paint Dryer, 6.5 Briggs (A52384)
Billy Goat Blower...
2016 KENWORTH T3 TANDEM AXLE REAR LOADER GARBAGE TRUCK (A53426)
2016 KENWORTH T3...
JOHN DEERE LOT NUMBER 29 (A53084)
JOHN DEERE LOT...
UNUSED WOLVERINE PFF3-13-45W UNIVERSAL MAST (A51248)
UNUSED WOLVERINE...
John Deere Gator XUV560S4 4x4 Utility Cart (A50324)
John Deere Gator...
