Multi G134
/ Multi G134 #1
basstracker
cincinnati ohio
ford 1620
I have a 1992 ford 1620 HST it calls for G134 hydraulic fluid but I can’t find any. Is there a alternative? I have never changed the fluid, do you just drain and fill, change the filters or are there specific things you need to do? Thanks
/ Multi G134 #2
Welcome to TBN!
New Holland dealers sell it as MultiGrade 134™ Hydraulic Transmission Oil, but any good grade like Shell Rotella HD, Mobil Delvac, Deere Hygard, Kubota UDT, Tractor Supply Traveler will work fine.
/ Multi G134 #3
I have a 1992 ford 1620 HST it calls for G134 hydraulic fluid but I can’t find any. Is there an alternative? I have never changed the fluid, do you just drain and fill, change the filters or are there specific things you need to do? Thanks
most any tractor hydraulic transmission fluid would work.
Don’t get the old 303 junk.
It’s also called Hy-Gard, (Deere), Hy-Tran (IH), perma-tran (MF), tractor trans, trans/hydraulic, or UTTF.
Dealer fluid is always good, but any fluid the farm stores list as meeting current specs is ok.
If it’s rated for wet brakes you’re good.
/ Multi G134 #4
Welcome to TBN!
Yep.
I have experience with those Tractor Tech listed....New Holland 134, Shell, Mobil, Deere, and Kubota hydraulic transmission oils. All are excellent. I've never used the Traveler brand from Tractor Supply, but I don't have anything against it. My bias is to stay with the premium brands I know.
rScotty
Kubota L3901HST
Kubota L3901HST
New/Unused AGT Industrial SDA-140W Mini Wheel Loader (A65583)
New/Unused AGT...
2015 Toyota RAV4 SUV (A61574)
2015 Toyota RAV4...
2022 EZ-GO ELITE...
New/Unused Quick Attach Landhonor Hydraulic Winch (A65583)
New/Unused Quick...
Schaben Pull Type Sprayer (A66285)
Schaben Pull Type...
