Mulching with the 60" MMM
   / Mulching with the 60" MMM #1
dtmarion
Bronze Member
Cumberland, Rhode Island
Jan 2, 2002 B7500
Mulching with the 60\" MMM
Is there some type of mulching kit that can be attached to the BX2200 or B7500 with the 60" MMM or do I have to buy a catcher? Just wondering...
<P ID="edit"><FONT SIZE=-1>Edited by dtmarion on 11/06/01 06:22 PM (server time).</FONT></P>
   / Mulching with the 60" MMM #2
Re: Mulching with the 60\" MMM
There is a mulch kit for the BX 60 inch MMM. I do not have a stock number but I have seen one installed--it is fairly pricey and probably not needed. The 7500---do not know, maybe someone else does. J
Re: Mulching with the 60" MMM
Why do you suggest that it's not needed. I'm curious because currently I mulch my lawn and I'm not to keen on idea of spending $1500 or so on a grass catcher with my new tractor. Do the three blades work that well?
   / Mulching with the 60" MMM #4
The 3 blades on my 60" mmm do a great job on the leaves in my yard, in fact, the last 2 times I mowed the yard it was more to clean up the leave than to cut the grass. The blades create a leaf mulch, i.e., there's not much left that's identifiable as a leaf.
Typically, I mow clockwise which means I am recutting the grass and leaves from the previous pass. For those areas that I can not mow clockwise, I make sure the discharge chute blows towards a hedgerow.
   / Mulching with the 60" MMM #5
If you keep your blades in good shape mowing over leaves with just the 60' MMM chops 'em enough where you don't even need to mulch. I'm always amazed at the quality of the cut provided, and even the occasional 1/2" thick stick gets pulverized with no problem.
2021 Doyle 8 Ton Trailer Tender (A52748)
2021 Doyle 8 Ton...
CATERPILLAR VC60DSA SHOP FORKLIFT (A52472)
CATERPILLAR...
2013 Dodge Charger Passenger Car, VIN # 2C3CDXAT8DH646721 (A51572)
2013 Dodge Charger...
1991 INTERNATIONAL WATER TRUCK (A52472)
1991 INTERNATIONAL...
NEW Wolverine Skid Steer Vibratory Roller (A53002)
NEW Wolverine Skid...
2008 CATERPILLAR 320D L (A52472)
2008 CATERPILLAR...
