Mulching Problem
/ Mulching Problem #1
dclaro
John Deere LA115
I'm getting lumps of grass when I mulch at 3". If I cut higher at 3-1/2" to 4" its better but the grass is too long. I have newly sharpened blades and the mower deck is clean and sprayed with silicone. I use "Gator" blades in the Fall for the leaves and this works great for that. In the Spring and Summer I've noticed no difference in the clumping so I switched back to Deere blades--with the same results. The mower deck is level and I mow at slow to moderate speed of about 3mph. Any tips?
/ Mulching Problem #3
Hello & WELCOME to TBN! :)
I moved your thread to the General Lawn & Garden Forum. If you have a mower, you might also be interested in our sister site, LawnMowerForum. Good luck!
2006 Ford F-750 Terex Commander C1017 Digger Derrick Truck (A64194)
2006 Ford F-750...
PULL TYPE YARD SPRAYER (A64278)
PULL TYPE YARD...
2015 International 4300 Elgin Broom Bear Sweeper Truck (A64556)
2015 International...
2014 Peterbilt 337 S/A 18ft. Cab and Chassis Truck (A64194)
2014 Peterbilt 337...
2012 Ford E-350 16ft. Box Truck (A64556)
2012 Ford E-350...
2020 Ford F-150 4x4 Ext. Cab Pickup Truck (A64194)
2020 Ford F-150...
