Muffler for 1-1/4" pipe????
   / Muffler for 1-1/4" pipe???? #1
Cord
Richfield, Wi
Resident Architect
It wouldn't seem so hard to find, but I'm searching for a muffler that would fit over a 1-1/4" pipe. I have an old Wisconsin engine and it has the threaded pipe outlet. There is a short stub of pipe and it's 1-1/4". I spent a bunch of time at my local farm supply store and came home with nothing. It looks like a 1-7/8" OD pipe gets really close, but it just fits over the tapered threads and won't fit the straight pipe. Wondering if anybody knows of a source for this muffler???
   / Muffler for 1-1/4" pipe???? #3
If you have enough pipe stub you can also get a universal muffler with 1 1/4" ID at most auto parts stores that will slip over the pipe.
Yes, the Stanley muffler is the one linked in the first post. It's the muffler that I used to have. It wasn't all that effective so I had stacked a second tractor muffler after it. Now that the Stanley has failed due to fatigue (inlet separated from the body) I'm looking for something better. I'm thinking of maybe just seeing if a muffler shop can swage the end to the correct size.
I actually have an expander, but I've learned that they work on paper, but just don't have the power necessary to really stretch a pipe.
   / Muffler for 1-1/4" pipe???? #8
Have you tried an impact wrench? I have used one with an impact wrench and it worked very well on muffler pipe.
Aaron Z
   / Muffler for 1-1/4" pipe???? #9
Aaron Z
It can also help to loosen the tool and turn it a little and re-tighten it again. And a good extream pressure grease on all sliding surfaces.
   / Muffler for 1-1/4" pipe???? #10
Make sure you don't try to expand the pipe too close to where the pipe is welded to the muffler. I've used the expander tool several times. It won't expand the pipe at the welds.
   / Muffler for 1-1/4" pipe???? #11
EDIT: Just realized Walker doesn't make one that small but leaving post for others needing 1-1/2" or larger.
I used this to find mufflers for my LMSC a while back. Got a part number I thought would work and ordered from Oreilys. Had them the next day at 7:30 AM. Little tiny mufflers knocked my 351W from 116 DB to 98. Track limit was 103 so I was golden.
WALKER® EXHAUST SYSTEMS :: Universal Muffler Dimension Search
2014 BMW 5 SERIES SEDAN (A59905)
2014 BMW 5 SERIES...
John Deere 3025E (A53317)
John Deere 3025E...
2026 Quality steel dump truck (A56859)
2026 Quality steel...
2451 (A60432)
2451 (A60432)
Crown RM6025-45 Stand-On Electric Forklift (A59228)
Crown RM6025-45...
2020 PRINOTH PANTHER T7R ROTATING CRAWLER DUMPER (A60429)
2020 PRINOTH...
