MTD Split-it log splitter
   / MTD Split-it log splitter #11
Isn't there supposed to be a dip stick attached to the cap to measure the level of fluid at the lower part/reservoir? Look and see if the dip stick has fallen into the bottom, or is lost.
   / MTD Split-it log splitter #12
Is the beam that the cylinder is connected to used as a reservoir? If it is I would agree that the oil has expanded due to heat and it is being relieved through this hole.
No dipstick and yes, the beam acts as a reservoir but it does it cold too.
   / MTD Split-it log splitter #14
If the fluid level is correct and the hose connections are at the proper locations I'd consider you may have sludge in the tube of that beam reservoir which may be causing the fluid not to disperse and rush out of the vent.
EDIT: Please give us more photos of the whole unit that is broad. Additionally, pull those 6 bolts on the end of your beam reservoir and see if there is sludge inside that has reduced the volume.
   / MTD Split-it log splitter #15
I have an old MTD splitter that has worked fine for 15 plus years. I had the same problem, oil coming out of the filler cap until I realized the unit had to be level to function properly. The instructions say to maintain fluid level 1/2 inch from the top of the tank but doing so requires the unit remain level. Occasionally, I have to re-level the splitter as use and vibration causes the fluid tank side of the splitter to sink down. I would insure the unit is level and there is an airspace between the fluid level and the top of the tank. Good luck, I hope your MTD works as well as mine has.
WOW, I long forgot about this old thread I started. Heres an update (10 years later!) This was EXACTLY the problem. The tube in the reservoir has a screen that was partially blocked with sludge. After cleaning that out and 2-1/2 gallons of new oil it worked like brand new and still does to this day!
   / MTD Split-it log splitter #17
I just got one of these. Needs new seals in the hydraulic cylinder, but when I turn the big nut it doesn't come out. Anyone ever had one of these apart?
Jim
   / MTD Split-it log splitter #18
Yes, a few. Look on the side for a slot, you’ll see an opening for a lock wire, the lock wire is suppose to come out when you turn the gland, unless the end of the lock wire is broken. Then you’ll have to get creative to pull it out while turning.
   / MTD Split-it log splitter #19
Thanks, I never would have seen that. I didn't find any sort of a hole for a lock wire yet, any more suggestions? I spun the gland nut all the way around a couple times and could only see a smooth surface. Couldn't even tell if it was turning.
Jim
   / MTD Split-it log splitter #20
The smooth surface you see is the lock wire, more than likely .125” square. You’ll need to get that cyl off and on a bench with the slot on top to see what’s going on with the lock wire.
2018 GENIE GTH636 TELESCOPIC FORKLIFT (A51246)
2018 GENIE GTH636...
2013 Vermeer V800 T/A Towable Vacuum Trailer (A50324)
2013 Vermeer V800...
2006 GMC C7500 DUMP TRUCK (A51406)
2006 GMC C7500...
2015 Infiniti QX60 SUV (A50324)
2015 Infiniti QX60...
2022 John Deere X9 1100 Combine, (A53342)
2022 John Deere X9...
2016 Nissan Altima 2.5 Sedan (A51694)
2016 Nissan Altima...
