Mtd huskee
/ Mtd huskee #1
Nfaile
Cud cadet ltx1040
I have a mtd huskee mower 38in 1997 when i try to crank it nothing happens at all no sound nothin. Any sugesstions
/ Mtd huskee #2
sounds like you have a bad battery connection. try wriggling wires while holding down the key to start it, or you have a safety device not making contact, such as the seat safety device. check the voltage on the battery if you have something to check it with , or put some jumper cables on it.
/ Mtd huskee #3
I have an MTD Huskee also. It's a different year and size, but my experience may be of some use. I found that the plug that went into the PTO switch had vibrated loose over the years. It was deader than a hammer! After charging the battery and changing the starter with no results, I noticed the loose wiring and pressed it back into place. It started and ran like a champ!
Hope this helps!
Chevrolet Metal Tailgate Metal Decorative Sign (A64557)
Chevrolet Metal...
2017 KUBOTA KX057-4 EXCAVATOR (A65053)
2017 KUBOTA...
2025 HOMESTEADER 612IT 12FT ENCLOSED TRAILER (A67148)
2025 HOMESTEADER...
2020 KENWORTH T680 6X4 T/A SLEEPER TRUCK TRACTOR (A67148)
2020 KENWORTH T680...
TAG 48" QUICK ATTACH EXCAVATOR BUCKET (A65053)
TAG 48" QUICK...
2016 Freightliner M2 106 Ambulance (A64556)
2016 Freightliner...
