Mtd huskee
/ Mtd huskee #1
Nfaile
Cud cadet ltx1040
I have a mtd huskee mower 38in 1997 when i try to crank it nothing happens at all no sound nothin. Any sugesstions
/ Mtd huskee #2
sounds like you have a bad battery connection. try wriggling wires while holding down the key to start it, or you have a safety device not making contact, such as the seat safety device. check the voltage on the battery if you have something to check it with , or put some jumper cables on it.
/ Mtd huskee #3
I have an MTD Huskee also. It's a different year and size, but my experience may be of some use. I found that the plug that went into the PTO switch had vibrated loose over the years. It was deader than a hammer! After charging the battery and changing the starter with no results, I noticed the loose wiring and pressed it back into place. It started and ran like a champ!
Hope this helps!
2015 Ford Explorer AWD SUV (A64557)
2015 Ford Explorer...
2022 EZ-GO ELITE...
2022 EZ-GO ELITE...
2025 BS43 44in. Hydraulic Boxbroom Sweeper Mini Skid Steer Attachment (A64553)
2025 BS43 44in...
2021 DITCH WITCH HX30G VACUUM TRAILER (A63276)
2021 DITCH WITCH...
2012 Kenworth T800 T/A Sleeper Cab Truck Tractor (A64194)
2012 Kenworth T800...
