Mtd huskee
   / Mtd huskee #1
Nfaile
Cud cadet ltx1040
I have a mtd huskee mower 38in 1997 when i try to crank it nothing happens at all no sound nothin. Any sugesstions
   / Mtd huskee #2
sounds like you have a bad battery connection. try wriggling wires while holding down the key to start it, or you have a safety device not making contact, such as the seat safety device. check the voltage on the battery if you have something to check it with , or put some jumper cables on it.
   / Mtd huskee #3
I have an MTD Huskee also. It's a different year and size, but my experience may be of some use. I found that the plug that went into the PTO switch had vibrated loose over the years. It was deader than a hammer! After charging the battery and changing the starter with no results, I noticed the loose wiring and pressed it back into place. It started and ran like a champ!
Hope this helps!
1043 (A50459)
1043 (A50459)
2013 Chevrolet Caprice Sedan (A50324)
2013 Chevrolet...
2013 FORD F-450 UTILITY TRUCK (A51222)
2013 FORD F-450...
2000 John Deere 1860, 30ft Wide, Gandy Box, Wing Fold, 7.5in Spacing (A52128)
2000 John Deere...
71060 (A49346)
71060 (A49346)
2016 INTERNATIONAL PROSTAR TANDEM AXLE SLEEPER (A51219)
2016 INTERNATIONAL...
