MT372D Mitsubishi Tractor
/ MT372D Mitsubishi Tractor #1
Skelley
Penna
Mitsubishi MT372D
I would like to ask about a starting problem I have with the tractor. I put the tractor away around October with it running fine. I go to try to start it in March and it will not start. I went over the fuel system with new filter and to see if the injectors are putting out. Everything checked ok. I checked compression and it looked good. I pulled the starter and check current and rpm's and it checked out OK. The only thing I am not sure about is the timing. Can the timing just Jump a tooth that would throw the timing out while trying to start it. Any suggestions would be great.
/ MT372D Mitsubishi Tractor #2
Does the engine not turn over or does it spin and not start?
This is the two cyl. right?
/ MT372D Mitsubishi Tractor #3
Don't take this the wrong way but can we assume that you did bleed the air after going over the fuel system? Have you checked the glow plugs?
/ MT372D Mitsubishi Tractor #4
It wouldn't jump timing.
/ MT372D Mitsubishi Tractor #5
You probably just have air in the system.
2012 PETERBILT 388 (A67714)
2012 PETERBILT 388...
2005 CAT 140H MOTOR GRADER (A67714)
2005 CAT 140H...
2014 MAC FLAMELESS HEATER TRAILER (A67714)
2014 MAC FLAMELESS...
2016 Ford Explorer AWD SUV (A66738)
2016 Ford Explorer...
2017 CHEVROLET TAHOE SUV (A66091)
2017 CHEVROLET...
2015 WILDWOOD 5TH WHEEL (A67714)
2015 WILDWOOD 5TH...
