MT372 Range shifter trouble
/ MT372 Range shifter trouble #1
D40
My gear range shifter quit on me today so it stays in the low range all the time regardless if it's in the Low or Hi position. Is there anyone who has had this problem and might know what it is that is causing this.
Thanks, David40
/ MT372 Range shifter trouble #2
Most likely pin or bolt in the linkage. it the shaft turns with the leaver then the problem is inside the gearcase. you will have to remove the seat and the hudrolic control unit to get to the gears and linkage. not realy so bad I have opened the gear case on my beaver III several times.
42" X 30" FIRE PIT RING/DISC (A64281)
42" X 30" FIRE PIT...
iDrive TDS-2010H...
2021 JOHN DEERE 331G SKID STEER (A62129)
2021 JOHN DEERE...
2015 Kawasaki Mule 4x4 Utility Cart (A61572)
2015 Kawasaki Mule...
FORD 4500 TRACTOR (A64280)
FORD 4500 TRACTOR...
2021 Mercedes-Benz Sprinter 4500 Modified Food Catering Van (A61574)
2021 Mercedes-Benz...
