MT372-CLUTCH
/ MT372-CLUTCH #2
It must be rusted to flywheel.
Check for water in bellhousing ( drain plug in bottom of bellhousing) then try pull starting to free clutch, this may take several attempts.
/ MT372-CLUTCH
THANKS FOR INFO. I DID NOTICE WATER DRIPPING FROM BELLHOUSING. I WILL TRY IT. THANKS AGAIN, KANRF.
/ MT372-CLUTCH #4
My S370D has the same issue with a stuck clutch. Bone dry at the drain. It was in my shop for another issue. After rebuilding the left spindle the clutch wouldn't release. Which range do you recommend pull starting the tractor?:confused:
/ MT372-CLUTCH #5
Hello, I just had the same problem. I learned the fix on another post in this section. Simply let it idle with the clutch pedal blocked in, and then drive
it around, also with the clutch pedal blocked in occasionally hitting the break.
It took approx 4hrs of running but it worked and I did not have to spend 2 days splitting the tractor. Be patient it may take longer.
/ MT372-CLUTCH #6
To start a tractor by pulling , put it in the highest gear.
/ MT372-CLUTCH #7
I tried the holding in clutch and braking while driving trick. Worked the first time! Just what I needed to clear road after having to walk/down the hill due to the snow. Nieghbors up the hill are greatful too.:D
/ MT372-CLUTCH #8
To prevent this, there is a little flip latch down by the linkage that you can use to hold the pedal down while the tractor is turned off.
UNUSED ATS POWER ATS-MIG-140 MIG WELDING MACHINE (A64281)
UNUSED ATS POWER...
6' ROTARY MOWER (A64280)
6' ROTARY MOWER...
EZ Trail 3400 (A64126)
APPROX (50) 2" X 2" X 22" TUBING (18) 2" X 6" X 51 (A64280)
APPROX (50) 2" X...
BRIGGS & STRATTON STORM RESPONDER GENERATOR (A64276)
BRIGGS & STRATTON...
2022 EZ-GO ELITE...
