Mar 18, 2023 / MT 372 clutch issues #1 JayRay48 New member Joined Mar 18, 2023 Messages 1 Tractor MT372 Mt372 tractor will still move forward and reverse and the lift works fine but I have no pedal when pushing the clutch
Mar 19, 2023 / MT 372 clutch issues #2 3gunr Veteran Member Joined Apr 17, 2018 Messages 1,182 Location wentzville mo Tractor mahindra 2538 mahindra 2810 cub cadet 7260 massey 255 Is this a hydrostat? I dont think Ls has an MT372 , Need more info.
Mar 19, 2023 / MT 372 clutch issues #3 C CADplans Elite Member Joined May 27, 2016 Messages 3,752 Location near Roanoke VA Tractor 584 IH 4WD I had a MT372,, You need to call Bill Rodgers at Valley Power in Roanoke VA. He will know what is up, and he is the ONLY source for parts. I bought mine off of Bill.
Mar 20, 2023 / MT 372 clutch issues #4 Roadworthy Elite Member Joined Aug 24, 2019 Messages 4,053 Location Southeast Washington Tractor Kubota L2501 HST, I believe Bill is deceased. What exactly is no pedal when pushing the clutch? Does that mean the pedal has no resistance or will not move at all? If it has no resistance check to see if something in the linkage popped out or became disconnected.
Mar 21, 2023 / MT 372 clutch issues #5 L lens12 Veteran Member Joined Apr 7, 2000 Messages 2,127 Location Dixon, Il Tractor ford 9700, tw30, massey, jd2030 jd4010, yanmar F60d, ym330d, ym276d,ym226d,ym186d, ym2000, ym155 Either a rod is disconnected or the pressure plate is shot. You'll need to split the tractor. I can supply parts.
