MT357CH
/ MT357CH #1
MT357
LS Mt357CH
I am having severe wiring issues from rats eating the wires, working to fix those jokers , but need help with error codes.
Can you purchase handheld reader that tells you where to look when you get codes on the instrument panel,
/ MT357CH
2019 late early 2020 ,
/ MT357CH
also will take folks advice on best rat/mice killer - - just tried using dryer sheets , they started making nest out of them // whats weird is i have two JD sitting under same barn . notta issue with those tractors.
/ MT357CH #5
Do my own pest control has some decent rat/mice poisons, but it depends on your state if they can ship to you. I've used both the Contrac (not available in CA) and Fastrac (Not Available in AK) for a roof rat infestation in a house that sits empty most of the time. Seems the critters eat more of the Contrac & leave the Fastrac for last. (as I understand it, there is a bittering agent added to the Fastrac to keep pets/kids from trying it as there is no antidote, so you are forewarned). I laid out both & started seeing/smelling dead rats within a few days.
As far as scanners, any code reader for heavy diesel should give you the codes. (Not Cheap and the connectors need to be matched) the Launch scanner x431 with diesel module is around 2k, the carnick scanner ls shows in the shop manual is over 3 k. The shop manual translates some of the dic codes into actual codes & provide daignostic procedures. Good luck on both problems.
/ MT357CH #6
Even rats don't like those Greene machines. Hahahahaha
Kubota V3600-E3-EG60 Diesel Engine - 3.6L - Tier 4i - Irrigation Pump Takeout (A63689)
Kubota...
2011 Jeep Grand Cherokee Laredo SUV (A64557)
2011 Jeep Grand...
2022 New Holland Boomer 45 (A64126)
2022 New Holland...
2014 GULF STREAM TRAILMASTER (A65643)
2014 GULF STREAM...
96in. Skid Steer Bucket (A65640)
96in. Skid Steer...
2013 PETERBILT 367 (A65643)
2013 PETERBILT 367...
