MT3 reliability
/ MT3 reliability #1
CloverKnollFarms
Super Member
Indiana
TYM4820H
So I admit I’m really on the fence between LS and Branson. The Branson I like due to the mechanical, non ECM Kukje diesel. I admit I’m a member of a couple LS groups on FB and see post after post about error codes, limp mode, DPF issues etc. I know many join such groups because they have issues they wish to resolve. The Branson group has many fewer issues. Not scientific.
I’d be looking for the MT352 or MT357, so I’m curious if any owners here have had regen issues, or electrical issues that should give me pause?
In this area LS has a slightly larger presence, and I do prefer the cab on the LS and like the rear 3 point lever. The draw of the Branson is the mechanical nature of the machine, alleviating a lot of electrical gremlins.
/ MT3 reliability #2
I have a 2019 XR4145HC (predecessor to the MT3, and I believe the same engine) with 180 (not a lot) of trouble free hours. My guess (I don't know) is that many of the dpf problems are caused by not running the engine at sufficiently high RPMs. The engines should be ALWAYS run at 1,800+ RPM, except when warming up and cooling down (for 1-2 minutes only).
When running mine at 1,800 RPM, I go into regen every 30 hours. If I run it at 2,500 RPM (what I always run it at now), it goes into regen automatically (software controlled/mandated) at 50 hrs, as opposed to going into regen because the DPF is full.
/ MT3 reliability #3
My LS is only 35HP and so far, no issues with regen. Word on the street is run them at 2k RPM or better and have fewer issues. I really like my LS Tractor. That said, when I was shopping, the nearest Branson dealer is 100+ miles away vs 8 miles for LS. Otherwise, I would have likely bought a Branson for a simpler machine with less to go wrong. Especially when ECM's have trouble, you're not likely going to be able to fix it yourself.
/ MT3 reliability #4
Owning and operating a more mechanical tractor, such as Branson, is a nice thing to have! Nothing wrong with them at all. They are simple, rugged, and reliable (from my limited experience with them).
LS (and other "computer controlled" tractors) are a bit more... complex. But not so complex that they are a bad tractor. ECU tractors are just as easy to work on, and if operated and maintained correctly, will last a lifetime. Branson's are a bit more forgiving, but LS's are a bit more comfortable.
Many people like to crap on these "Chinese" tractors because they are not made in the US (Seriously, the comments I get on my YT channel, people say the strangest things without a hit of homework). They join groups and watch videos of LS (and others) breaking down and having issues. Trouble sells. One of my most watched videos was when I broke down (caused by operator error). I try to paint the LS tractors for what they are, a reliable, affordable, feature rich tractor that is just as capable as a JD or Kubota.
My tractor, the XR4145C, is the father of the MT3 series. It's essentially the same tractor, with the same engine, but with less features. I have owned it since April 2018 and the only issues I have ever had with it was all due to my negligence. I have since looked at a friends Branson (model escapes me) and I honestly like it. Its just a simple tractor. No frills, no electronics, no amazing features.
If I had to do it over again, I'd still buy my LS. Even if my budget allowed for a John Deere or Kubota. Id buy the LS. I'd probably go a bit bigger though, since bigger is almost always better.
/ MT3 reliability #5
I spent most of last year trying to decide between Branson, Kubota, and LS. On price, Branson and LS win the battle over Kubota with way more standard features for the price. I drove them all and was nearly convinced to buy a Branson due to its simplicity. The Kubota tractor is probably built better since they have been at this for a long time and understand their customer. LS gives you the upper end Kubota features and an equivalent or lower price than a Branson - plus a New Holland dealer won't be afraid to work on it. What killed my choice of Branson was the unavailability of their product and its effect on the dealers in my area. My closest Branson dealer maybe got 3 or 4 tractors all year! How can a dealer network survive with that lack of product? I could have bought a Kubota from multiple dealers all year long. In the end I bought the LS MT3. While some dealers in my area could hardly get product, the dealer I bought from stated they sold 350 tractors last year in northern WI. I think they are trying to sell 500+ in 2022. I think they will be in business for a while.
There seems to be a tremendous fear factor of the emission controls on the new tractors. Kind of reminds me of the 70's with catalytic converters on cars. That technology was in its infancy back then. Electronics are much better now. Would I rather not have a DPF and DOC on my tractor? From a simplicity standpoint yes, but when I'm using the tractor in the shed it is nice to not have the heavy diesel fumes and soot. I would like to be able to idle a little more without the buildup of soot in the DPF though. These newer diesels run so nice that running them at higher speeds is no big deal. They also probably use less fuel than older diesel engines even when running them up in speed. Just about every new tractor has around a 6 year warranty on the powertrain which would include any issues with the emissions equipment.
Bottom line for me was that I'm not a high hour user so maybe the Kubota or JD was not what I needed. I like the extra features of the LS (like extra rear remotes, cruise control for speed and engine rpm, and a reasonably priced cab version). I probably would have bought a Branson but there were none available even for a test drive which lead me to the LS brand. Haven't had a problem and don't regret the purchase.
/ MT3 reliability #6
It took me 2 month to pick my LS from all the compact tractors out there. I have 6 different tractor dealers about an hour plus away. Mine is the smaller than the one your looking at but it has done every thing I needed it to do and more. I now have over 152 hours on her and I am still loving her.
/ MT3 reliability #8
I'm totally happy with my MT352 with cab. Its bigger than I need (for now) has every feature you can get on a tractor standard with Cab model.
I just spent 6 hrs pushing snow on Monday in -10C temps while it was still snowing.
I was REAL nice had to take off my jacket and open a side window to keep cool and my coffee fit nice in the cup holder. lol
Was real nice just set the rpms at like 1800rpms and go - Ive got the shuttle shift and doing FEL work with snow was a breeze. for 52hp its got plenty of grunt and built like a tank.
No issues here very happy owner.
/ MT3 reliability #9
I looked at the LS for about a year. Since I waited the MT3 came out and the PTO neutral was a big deal for me. I have about 120 hours and have no mechanical complaints. It starts and does its work every time.
I did have some warranty work done last year, 3pt valve, PTO and 4wd seals. Still waiting on a right hand loader mount as the original is a bugger to get the pin in and out. Small things but the dealership is taking care of me.
I have only had JD compact tractors for the 20+ years prior to the LS, New Holland 40 (XR3140) and the MT3. I will say that the capability is on par with JD/Kubota/Massey but some items takes a bit of adjustment on the LS. Call it OCD or whatever, but I've modified just about all of the "bug me items" or have plans to complete them, for all the items I wanted to adjust to suit me better.
I like the tractor and its capability. Would definitely buy again.
/ MT3 reliability #10
LS XR 4155 owner here, 165 hours and I believe it has only regenerated twice so far. It seems to start and run perfect, does everything it’s supposed to do and does it very well.
Seems like way to many owners fail to read the owners manual that comes with the tractor when new, failing to read that pretty simple manual often leads to trouble that could of been easily avoided.
The newer MT series has some very nice miner improvements but it obviously costs more as well.
I also like the Branson tractors but when buying my LS the nearest Branson dealer was about 100 miles away, they do have a much closer dealer now.
/ MT3 reliability #11
I sorta remember when looking at the 2021 model 5520H Branson that they added a exhaust flap in the outlet of the exhaust pipe to trap more heat in the manifold during a regen. Sounds like a good idea but I thought I was told by he dealer you need to park the tractor during this event. On the LS and most other tractors you can work the tractor and keep it in regen as long as you keep it above a certain rpm or you can park it and run the engine at higher engine speed. Maybe someone with a Branson in this size can add to this.
/ MT3 reliability #12
I had an error code once on my MT357. Turns out the super tall thick briers I was cutting with the flail mower had tore a wire out. I reconnected the wire and zip tied it out of the way, that was the only error code I had.
It regenerated right at 50.0 hours and I didn’t even notice it (other than the light on the dash). I use mine mostly for flail mowing, so it mostly runs at pto speed.
this is my first tractor ever, so I can not comment on anything else about it.
/ MT3 reliability #13
I'll jump in here...
We bought a LS XR 3140H in 2020. The only thing wrong with our tractor was one of the stop blocks that when you curl the bucket back up was higher than the other. It would touch almost a full quarter inch before the other side would, Dealer ground it down till both stops engaged exactly. I thought the tractor had a front axle pivot issue, rear pivot missing a grease fitting, turns out it gets its lube from the oil in the differential instead of grease.
At 172 hours now, it has regen every 50 hours like clock work. I did force a regen at 15 hours because of low rpm use and not getting to operating temps. Since the 15 hour mark, its 1800-2000 rpm after a couple minute idle. Zero regeneration issues or any other issues so far with the LS.
/ MT3 reliability #14
Ls is a good tractor. I would not be worried about the emission issues. The down side is you need to keep them at a high idle to keep the soot burned out. Dealer told me around 1800 rpm’s. Burns more fuel. Nice thing about the Branson Kukje engine is you can take all that emissions crap off and idle like a regular tractor. Less fuel, wear etc. I’m not saying for you to do that. Just saying that if that stuff would fall off it would run fine. I don’t want to upset the EPA trolls. Demo both and pick which one suits you better. If you look on the net you will find bad things happen to everything.
/ MT3 reliability #15
I'm not sure if you can just remove the DOC/DPF on the latest Bransons like in the past and install a muffler with no repercussions. Thought I read a thread on TBN that you can remove those components but you'll get the DPF light. Not sure if it still tries to run the regen at the 50hr threshold which does require the tractor being parked.
/ MT3 reliability #16
Every tractor product line has it less desirable model. I have not experienced this with LS. What I have found LS use base motor that is tuned for 35,40,42,52,55,57 HP. Turbo adds in the kicker on torque and horsepower. I have LS XR3135 HC with 160 hours with backhoe. I have used the past 160 hours with backhoe service. No let down on performance in my current use. I have read in the threads LS has sub-supplier with harness issues. Finding tractors with wrong harness versions on them. My guess either the sub-supplier is in question on craftsmanship which is confusing since the harness should be load tested using HYPOT tester and or ohm inspection. This should be done by software looking for errors. Or the problem could be mislabeled harnesses in stocking location. Again as they are testing tractor any harness issues should be coming up during cycle tests. I can say with confidence they are performing continuous improvement just as all other suppliers. Our feedback is being read and reviewed by their quality team. Otherwise things would be worse they are improving. Again this is true across tractor lines in the marketplace today. I will say as all others agree upon on this site. Putting electronic EPA controls Tier IV on compact tractor used less than 200 hours year was not the smartest decision but it was necessary to eliminate complaints on larger HP tractors. We all suffer from this directive.
/ MT3 reliability #17
I just bought an MT357HC about a month ago. I have 14 hours on it now. I am fairly hard on equipment, I run a sawmill and logging is no easy task for a tractor. Heavy lifting and transporting logs over uneven and often muddy terrain. In the 14 hours I have on the tractor, so far I have not detected any weaknesses. It is very strong, great lift capacity, smooth, quiet, and fuel efficient. I love the cab. I came from a Kioti DK40 open station, and didn't know what I was missing without a cab. My tractor went into regen at 13 hours.. and it was a simple 15 minute process. I was moving some logs and the light came on the dash. Shortly thereafter the other light came on (there are 2 lights... 1 that indicates it is ready to regen, and the other indicating that the engine temp is high enough to regen). As soon as I saw the first light, I cranked the rpm's up to 2,200 and kept working. Both lights stayed on for about 15 minutes, then they went off and it was done. Did not affect me in any way whatsoever. I did notice a different smell from the exhaust, but that's it. Nothing to be afraid of. They are constantly improving these tractors, and in my opinion the MT3 series tractor is very well made. This is however on a tractor with only 14 hours, so it's not broke in yet. I plan on giving more reviews when it gets a few hundred more hours on it. Main thing is, periodically check the important bolts and make sure they aren't getting loose (lug nuts and loader mount bolts), stay on top of your fluids, use proper fluids and filters, and run your machine at 1800 rpm's minimum most of the time, and you will be fine. These tractors have a 2 year bumper to bumper and 6 year powertrain warranty. That's pretty solid. If you have a good dealer nearby, don't hesitate.. go for it! You certainly won't beat the bang-for-the-buck!
/ MT3 reliability #18
I'm just over a year in on my MT352HC and have been very pleased. I crossed over 140 hours this week and it has seen some hard use this past year. I had one problem with it that the dealer and warranty took care of, outside of that I got no complaints.
2004 Freightliner FL70 Garbage Truck, VIN # 1FVABTCS64HM47795 (A61165)
2004 Freightliner...
2025 Pabreak Hydraulic Rotary Tiller Skid Steer Attachment (A61567)
2025 Pabreak...
2025 Pabreak 74in. Hydraulic Dual Cylinder 4-in-1 Bucket Skid Steer Attachment (A61567)
2025 Pabreak 74in...
Godwin CD150M Dri-Prime Towable Trash Pump (A61567)
Godwin CD150M...
2025 Spirit Electric Scooter (A61569)
2025 Spirit...
UNUSED KJ K1522 PORTABLE RESTROOM (A62131)
UNUSED KJ K1522...
