MT240 or similar rear remote hose connections
   / MT240 or similar rear remote hose connections #1
JCoastie
Platinum Member
Coastal AL
LS MT240HE
Does LS use ball or valve type connections for the OEM rear remotes?
Ball
Valve
   / MT240 or similar rear remote hose connections #2
On mine, they are the valve type. OEM remotes.
thank you
   / MT240 or similar rear remote hose connections #4
Valve on my MT240
perfect, thanks
   / MT240 or similar rear remote hose connections #6
Most newer tractors should use the poppet style quick connect, your valve picture.
Either ball or poppet will interchange with one another and work fine together.
   / MT240 or similar rear remote hose connections #7
That's good to know, Thank you!
UNUSED FUTURE...
Case 950 8 Row Air Planter (A55315)
Case 950 8 Row Air...
DEUTZ MARATHON 60KW GENERATOR (A58214)
DEUTZ MARATHON...
2013 Vermeer V800G T/A Towable Vacuum Trailer (A56857)
2013 Vermeer V800G...
Landoll Lowboy Trailer (A55315)
Landoll Lowboy...
2018 Ford Fusion Hybrid Sedan (A56859)
2018 Ford Fusion...
