MT240 or similar rear remote hose connections
   / MT240 or similar rear remote hose connections #1
JCoastie
Coastal AL
LS MT240HE
Does LS use ball or valve type connections for the OEM rear remotes?
Ball
Valve
   / MT240 or similar rear remote hose connections #2
On mine, they are the valve type. OEM remotes.
thank you
   / MT240 or similar rear remote hose connections #4
Valve on my MT240
perfect, thanks
   / MT240 or similar rear remote hose connections #6
Most newer tractors should use the poppet style quick connect, your valve picture.
Either ball or poppet will interchange with one another and work fine together.
   / MT240 or similar rear remote hose connections #7
That's good to know, Thank you!
2014 Gravely 60" Zero Turn Commercial Mower (A55973)
2014 Gravely 60"...
2015 Toyota Prius Hybrid Sedan (A56859)
2015 Toyota Prius...
LIMA MAC 60KW GENERATOR (A58214)
LIMA MAC 60KW...
SCAN TO RECEIVE TEXT UPDATES (A52709)
SCAN TO RECEIVE...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2013 FREIGHTLINER CASCADIA (A58214)
2013 FREIGHTLINER...
